Welcome, Cory.
Originally Posted by Cory
The original subfloor is some type of MDF but it has an orange color to it.
Think we've heard of some sort of orange-lookin' flooring up yonder in Canuckistan. That where y'all are? See can you find a stamp on that subflooring somewhere to help identify it. The thickness is unusual and leads to speculation about it having been wet sometime in its life.
It's unusualy for engineered floor systems to be designed below the code-required L/360 deflection, but it could happen, I suppose. It's more common for them to be designed to L/480, 'specially in longer spans, but yours don't look heavy enough to get there with that spacing. That's a guess, of course.
Try to find a manufacturer's stamp on one of those joists and contact them. That's the only real way to determine what you've got for design deflection.
Yes the vinyl has been removed (fire) but the 3/8 is still there becuase it is stapled ever 2 inches it seems.
Ain't nobody promised you easy, eh?
I doubt the underlayment is really 3/8ths plywood of suitable characteristics for a ceramic tile installation, but I suppose that's possible, too. Almost certain it's gotta come out, though.
And with the unknown properties of the existing subfloor, I'd not want to tile without adding a suitable layer of plywood over what you've got. I'd recommend a half-inch minimum thickness.
On your shower pan dilema, my recommendation, if you are not going to fix the underlying problem, would be to abandon the pre-fab receptor and build your own shower pan. Either a traditional pan, or a Kerdi System pan. Either one would permit you to disregard the sloped floor inside the shower area. Might look a little funny from the outside, though, but no funnier than that pre-fab jacked up on one end.
