-   -   Bathroom rebuild 5' x 10' - new sunken shower (https://www.johnbridge.com/vbulletin/showthread.php?t=114229)
01sesedan 03-12-2015 02:38 PM
For you guys that have installed barrier free, curbless, walk in, drop down shower. Have you placed a capillary break about 12" from entry? I've read on the web it's a good idea to prevent water wicking into the bathroom.
Just wanted to get input from others.
Thanks again.
cx 03-12-2015 05:38 PM
A drop down shower is not gonna be barrier free, Joe.
I've done lots of dropped showers in concrete SOG foundations and have never done anything that could be called a capillary break on accounta I honestly don't know what that would mean in this particular application. Just what is it you're being told to do?
01sesedan 03-12-2015 06:07 PM
Here's my understanding from what I've read. Around 12" from the drop should be sloped to the pan. At that point were it slopes (12") install an L shape tile profile glues/sealed to the membrane. This should keep moisture in the wet area when you exit the shower. The moisture will work its way back to the pan.
Also, if the drain has a blockage/back up, the water level could go up close to the L tile profile. This should keep the bathroom floor dry. Once over the L profile, then your in trouble.
What do you think? Not needed on SOG?
The logic makes sense to me. Just wondered what you guys thought or has anyone completed this type of install.
