-   The Mud Box (https://www.johnbridge.com/vbulletin/forumdisplay.php?f=5)
-   -   deck question (https://www.johnbridge.com/vbulletin/showthread.php?t=126963)
lati_cz 02-14-2019 07:13 PM
deck question
I have to build a deck (simple rectangular shape, small). What's best system/way to install composite decking with no visible screws on top of boards?
cx 02-14-2019 07:18 PM
What specific decking, Michal? Some of those composite manufacturers have their own hidden fastening systems. Similar fastener systems can be used with square-edged boards with the use of a plate joiner or router.
lati_cz 02-15-2019 07:13 PM
They are selecting from 3 manufacturers. I will have the answer next week, thank you,
Kman 02-16-2019 05:28 AM
I was able to price composite boards with and without grooves cut into the edges to allow for the clips to attach them at every joist.
Of course, the cost is much higher for the boards, and for the clips. They don't seem like much individually, but start counting up every intersection between deck board and joist and it adds up quickly.
In the end, I found it easier and cheaper to simply take a materials list to the local hardware store and they gave me the best price. This was for approximately $8G in materials.
lati_cz 02-28-2019 02:43 PM
deck question
I will build deck 8 x 10', 10 is ledger side attached to house, it will be approx. 48" above ground. How many footings and what size do I need on longer 10' side?, can I get away with 2? What size of beam I need between those footings/posts? Thank you, Michal
Kman 02-28-2019 03:52 PM
It depends. If you're trying to have the least amount of footings, then you'll need heavier lumber. And vice versa.
Which is more important? If a third footer in the center of that 10' run is going to be an eyesore, or the customer just doesn't want it, then you'll need a 2x10 or 2x12 for your rim joist.
wwhitney 02-28-2019 07:51 PM
Check out DCA6, the Prescriptive Residential Wood Deck Construction Guide, published by the American Wood Council:
https://awc.org/codes-standards/publications/dca6
It answers your questions and more.
Cheers, Wayne
lati_cz 02-28-2019 08:33 PM
I am doing 3 posts, I will run "skirt" all the way down to hide the structure, so no issue with eyesore... Thank you!
