Old 03-07-2004, 12:36 AM   #1
Stew
Granite backsplash; edging recomendation
I thought I was in over my head with my most recent job until stumbling onto this forum. The knowledge and willingness to help others has reaffirmed my faith in mankind, although the Colorado drivers do their best to ruin my newfound optimism. Maybe someone can start a "driving forum" - one suited to warm weather drivers now residing in the Rocky Mountain region.
I will be embarking on a granite tile countertop job soon and am unsure how to handle the top edge of the backsplash. The backsplash will consist of 6 inch granite tiles. Before installing the granite tile backsplash, CBU will be used to build out the wall since tile is also being used on the front edge of the counter (owners don't want to use bullnose on the front edge, don't want a "sliver" tile in back, etc - so I will build out the backsplash to compensate for the needed space).
The Schluter line of products are new to me - do they have any products designed for this predicament? It was difficult to tell when visiting their website, and I'd much rather heed the advice of a professional than someone trying to sell a product.
Do any of you have any other products/recommendations on how to give this backsplash edge an attractive appearance - other than having the edge bullnosed?
Thanks in advance for your advice.
Hung like Einstein and smart as a horse.
Stew is offline   Reply With Quote
Old 03-07-2004, 10:36 AM   #2
T_Hulse
Tile Contractor
T_Hulse's Avatar
Hi Tom,
Maybe you could show the owners the picture below as an example of the sliver in back. It's really inconspicuous back in the shadows if you use a matching color grout. It's pretty much an industry standard for granite tile. I would think it would also be less conspicuous than than an akward transition where you have to hide the edges of granite & built-out CBU.
Tom Hulse
Visit my web site here
Old 03-07-2004, 10:52 AM   #3
Stew
Tom,
That's beautiful work.
Assuming a "sliver" in back is used, do you just leave the unfinished granite backsplash edge alone? The tiled backsplash will only extend a few inches up the wall, so there will still be an abrupt ending.
I've also run across someone before who had the same problem. They had a beautiful granite countertop with granite used for a backsplash (just a few inches worth), then it just abruptly ended - and they too wanted a way to give the edge a more polished look.
I don't think any type of wood trim used along the edge would do the counters much justice either.
Thanks again for the input.
Tom Stewart
Old 03-07-2004, 11:22 AM   #4
Hi Stew, nice work Tom. If you are going to use CBU behind the splash you can cut a cap piece to cover the top edge of the granite and the CBU. This edge would need to be bullnosed or polished flat. Without the CBU behind it, the backsplash piece would need to be bullnosed or polished flat.
Old 03-07-2004, 07:05 PM   #5
T_Hulse
Tile Contractor
T_Hulse's Avatar
Here is what a 4" granite splash would look like. Flat polished edge, no bullnose. I think 6" high is more common.
Tom Hulse
Old 03-07-2004, 07:11 PM   #6
Mike2
Thumbs up
Remarkable work Tom H.
You set a very high bar.
Old 03-07-2004, 08:18 PM   #7
Nice, Tom.
Stew,
The Schluter trim most often used in situations like that is "Rondec." It comes in many heights or widths and in different colors. Granite tiles are usually around 3/8 to 7/16 inches thick, so a 7/16 Rondec would probably do it.
