Old 02-24-2012, 12:11 AM   #31
Obie1
Tile Contractor
Obie1's Avatar
no need to seal the tile. If you didnt use a urethane or epoxy grout than sealing is an option. you can find numerous grout/tile sealers in any of your big box stores.
-Obie
ELITE TILE WORKS
(805)845-8787
Southern California ceramic and stone tile contractor serving Santa Barbara and Ventura counties
http://www.elitetileworks.net/
Obie1 is offline   Reply With Quote
Old 02-24-2012, 12:22 AM   #32
PetrH
I think what Obie means is seal the grout, not the tiles. Porcelain tiles will not benefit from sealer, but your grout will become more stain resistant with it.
Petr
Old 02-24-2012, 12:30 AM   #33
Jim Farrell Tiler
Jim Farrell Tiler's Avatar
some porcelain needs to be sealed
Jim
no matter where you go.......there you are
Jim Farrell Tiler is offline   Reply With Quote
Old 02-24-2012, 12:57 AM   #34
Obie1
Tile Contractor
Obie1's Avatar
Ok ok.....If you should have an unglazed porcelain Irving, then you might want to apply a sealer. I stand corrected
Should you decide to seal the tile, just remember to start with a small test area to make sure the sealer you have will be accepted by the porcelain.
-Obie
ELITE TILE WORKS
(805)845-8787
Old 02-24-2012, 01:43 AM   #35
Jim Farrell Tiler
some polished porcelain needs sealed
Jim
Old 02-24-2012, 08:59 AM   #36
RaymondJ
Addicted to Portland Cement
RaymondJ's Avatar
More to the point, who is gonna sit there and just seal the grout lines; use a spray-able penetrating sealer, spray the grout lines,tile and all, let it seep in and then wipe it off with a lint free rag
I like miracle 511 myself
Raymond
My work so nice! (cause I does it twice )
RaymondJ is offline   Reply With Quote
Old 02-24-2012, 11:01 AM   #37
Irving
The tile I have is "Capri Collection Classic 6x6 Through Body Porcelain. Class V porcelain strength. Glazed porcelain strength" Item number 77728.
Is there some type of sealant than can be applied over the tile and grout to stop, or reduce, penetration of water?
James
Irving is offline   Reply With Quote
Old 02-24-2012, 01:35 PM   #38
Pirate
I guess you could paint on a couple layers of epoxy.
I'm being sarcastic, but that seems to be what you are asking. There's no good solution here.
Randy
Pirate is offline   Reply With Quote
Old 02-24-2012, 01:52 PM   #39
James, under the American industry standards your tile is either Porcelain or it's not. If it is, it has a water absorption of 0.5 percent or less. You're not gonna improve upon that without changing the appearance, as with Randy's epoxy recommendation.
You'll not have much moisture penetration through the tiles, but the tile is not waterproof.
Tiling/Backerboard/Drain for Shower Questions BuckeyeMac Tile Forum/Advice Board 24 09-15-2011 08:07 PM
Tiling Shower, backerboard now not flush with wall akazmier Tile Forum/Advice Board 3 04-03-2009 06:36 PM
1/4" backerboard OK for tiling above tub/shower? golfinfool Tile Forum/Advice Board 4 03-07-2009 12:06 PM
Kerdi wall drying time before tiling? billa Tile Forum/Advice Board 3 03-20-2005 09:54 PM
Shower wall backerboard and tub deck ?'s Tile Board Lurker Tile Forum/Advice Board 5 02-27-2003 04:18 PM
