Old 01-21-2012, 04:45 PM   #1
tileneo
What will add shiny finish to porcelain tiles before or after sealing them
I just have someone install porcelain tiles on my shower wall
and bathroom floor. Obviously I need to seal them. But the tile
looks dull. I wonder what will add shiny finish to porcelain tiles.
What products are recommended?
Before or after sealing the tiles and grout ?
Thanks a lot.
Lucy
tileneo is offline   Reply With Quote
Old 01-21-2012, 05:20 PM   #2
sorry, nothing you can add to the porcelain tile to make them shiny.
are your tiles porcelain and a matte finish ?
you can seal unglazed porcelain but shiny wont happen.
Old 01-21-2012, 05:33 PM   #3
tileneo
can I use BOTH Penetrating Sealant and high gloss Sealant
Looks like Penetrating Sealant is for the long term, good for grout and porcelain.
In order to make it shine, need to use topical/high gloss Sealant.
So can I use Penetrating Sealant first and then high gloss Sealant
at the same time on my porcelain tiles ??
lucy
Old 01-21-2012, 05:43 PM   #4
tileneo
Use BOTH Penetrating Sealant & high gloss Sealant ?
at the same time on my unglazed porcelain tiles ??
lucy
Old 01-21-2012, 05:58 PM   #5
gueuzeman
Lucy, you should probasbly run some tests on a few leftover pieces before comitting to anything.
I have to ask, you picked these tiles out to start with, right?
gueuzeman is offline   Reply With Quote
Old 01-21-2012, 06:15 PM   #6
Lucy,
you just started this thread 56 mins ago.
http://www.johnbridge.com/vbulletin/...ad.php?t=98725
the mods like 1 thread per discussion.
Old 01-21-2012, 06:43 PM   #7
TeomanTile
In woodworking they do this al the time, the penetrating being the stain, the poly as the protection. Some even use different finishes for different looks, for example, I've used a semi gloss for the first coat, and a satin for the second coat of poly for a sheen between the two.
Since tile isn't wood, definitely run some tests, as geuze said, but in theory, it should work!!
Joseph Teoman
Teoman Tile & Stone
Friends call me JT!
TeomanTile is offline   Reply With Quote
Old 01-21-2012, 07:47 PM   #8
chefwong
Depends....
The solvents in the 2nd sealant may wear off some of the previous sealant.
Should be able to layer, just depends on product combo
alan
chefwong is offline   Reply With Quote
Old 01-21-2012, 09:48 PM   #9
doitright
doitright's Avatar
Hi Lucy, Welcome!
I'm going to split you off into a new thread.
Regarding your question, no you can't apply the topical over an impregnating sealer. It's not suggested, nor will you get a good bond.
John Koessler
Old 01-21-2012, 10:02 PM   #10
doitright
doitright's Avatar
Hi Lucy
I'm merging your thread to a single thread in the Restoration forum. As Brian said, we need to keep everything together.
John Koessler
Old 01-22-2012, 01:23 PM   #11
gsr
Not to hijack this thread or anything but isn't porcelain, even unglazed, impervious to almost anything?
If so, not much is going to stick to it, or penetrate?
Geoff
gsr is offline   Reply With Quote
Old 01-23-2012, 05:04 PM   #12
doitright
doitright's Avatar
Hi Geoff
You're not hijacking, it's a valid question.
We normally recommend sealing polished porcelain tiles (because of the micro fissures).
I also seal the honed tile while sealing the grout. Yes, they are impervious, but they do have a small percentage of absorption. Solvent and water based sealers react differently as well.
As long as the sealer doesn't leave a noticeable film (because it wasn't buffed off), it's my opinion that sealing is an option.
John Koessler
Old 01-26-2012, 03:33 PM   #13
StoneTooling
Vending Machine
StoneTooling's Avatar
You're right, sealing is an option but I don't think a penetrating sealer will be of much use. Also, with porcelain, if she does decide to seal, only 1 sealer will do. No need to impregnate and use a topical sealer.
Lauren V.
StoneTooling Now shipping internationally!
Visit us and purchase through the sponsored link at the bottom of the page to support the JB forums!
Contractors - send us your information to be listed on our contractor page.
StoneTooling is offline   Reply With Quote
sealing porcelain tiles? shirley holmes Cleaning, Restoration and Sealing 1 12-23-2006 08:51 PM
how to make porcelain tile shiny jody2006 Tile Forum/Advice Board 1 07-18-2006 03:53 PM
Porcelanosa 18" shiny porcelain tile Rhona Tile Forum/Advice Board 2 01-17-2004 07:06 PM
How can I add a high gloss finish to non-porus glazed ceramic tile? master_slacker Tile Forum/Advice Board 4 01-12-2004 06:28 PM
Do Porcelain Tiles Need Sealing spdom1 Tile Forum/Advice Board 3 12-01-2002 05:06 PM
