Old 01-15-2012, 07:15 AM   #1
tulse
Kerdi over Kerdi Tray before or after tiling walls?
On small 32"X36" shower floor...
I'm concerned about working and walking on a Kerdi covered Kerdi tray. I feel I'd be trampling the fabric and mortar if I tiled after I Kerdi'ed the floor (in such a small area). So, out of the two options, which is easier or "better":
1. Kerdi the whole shower, then protect the floor while tiling (I have some pink foam board insulation I can use).
2. Kerdi the walls only. Use a ledger board and tile the walls first, leaving the last row of tile out, then Kerdi the floor. Install tile over floor, the install last row of tiles.
I will be doing a vertical running bond of 12"x24" tiles.
Sam
tulse is offline   Reply With Quote
Old 01-15-2012, 07:17 AM   #2
Sam,
Lots of Pro's leave the floor till last, especially those of us who have gravity where we work.
Paul
Old 01-15-2012, 07:30 AM   #3
tulse
Gravity is hell here. I kind of messed up the first post. I will be installing the floor tile last either way.
I was just anxious to get the water test done before tiling the walls, but I think I'll take the leap of faith and wait to put the Kerdi on the floor until the wall tiles are done.
So, it's not advisable to go sashaying all over the Kerdi membrane on the floor I take it.
Thanks.
Sam
Old 01-15-2012, 07:45 AM   #4
I would kerdi both the wall and the floor at the time you are doing kerdi and
then protect the kerdi & tray with a drop cloth, cardboard, etc.
........Tampa Florida Tile Installation
..................Check out our Blog
Florida Installer of Laticrete HydroBan & HydroBarrier
....Florida Installer of Schluter Kerdi & Kerdi-Board
................."Waterproofed Tile Showers"
........Porcelain - Travertine - Ceramic - Glass Tile
Old 01-15-2012, 09:07 AM   #5
Protect the kerdi as though it were a finished hardwood floor. Vacuum it well, then add a slip sheet of paper before topping it off with drywall, old carpet scraps, layers of cardboard or what ever is handy that will bend with the shower floor curves.
Paul
Old 01-15-2012, 11:40 AM   #6
alfaman
i'm in the process of doing what your're doing now...here's some advice for what it's worth, from a diy guy
1. do the floor last..or you'll have a mess
2. do not put up large sheets (as john does in his book...."going for the gold"
MUCH easier to put on smaller sheets and "lap them" (for a first timer)
3. round off the edges of your trowel..sooner later you'll poke a hole in the kerdi if you don't (or maybe it's just me)..i ignored that advise and wish that i hadn't
4. lash system works great...i modified a cheap "visegrip" type tool form harbor freight and have minimal "lipage"...search it on this forum....i reduced the "bend" in the tabs using a hot air gun....
rick
alfaman is offline   Reply With Quote
Old 01-16-2012, 07:27 AM   #7
tulse
Thanks all.
I made the decision to only use half sheets right after I tried a whole. I was just testing fitting a whole (no thin-set down) when I decided to get the scissors out.
One more quick question:
Do you nail up ledger boards? Would screwing them up wrap the Kerdi up in the screw and pull it away from the wall?
Sorry for being so anal-retentive, but I only want to do this once.
Sam
Old 01-16-2012, 07:44 AM   #8
I've heard of no issues with driving screws through Kerdi that can't be addressed when you patch the holes later.
Old 01-16-2012, 07:53 AM   #9
tulse
Thanks.
I have Kerdi-fix. I just didn't want to end up with 50 bucks worth of Kerdi ripped of my wall and wrapped around a five cent screw.
Sam
Old 01-16-2012, 01:47 PM   #10
You could cut a sheet of ply the proper height and width and just prop it against the wall or wedge it there...no holes, nothing to repair.
Longtime lurker, avid DIY'er
Old 01-17-2012, 09:09 AM   #11
alfaman
i used a ledger...screwed into the walls...use at least a 1x6 board...screw in toward the bottom of the board (hole will be easier to patch and get the two inch overlap)
kerdi -fix the hole an patch with kerdi...no leaks in mine...my tiles where heavy 18 x 18 inches
rick
Old 01-18-2012, 12:48 PM   #12
tulse
Tulse's Bathroom Project
I read some back posts, but didn't see much in the way of anyone who has done it.
The concerns I've read are with point loading it. Of course, I read all this after the tray and drain have been installed, Kerdi'ed over, and after I bought the Pebbles.
Anyway, the Kerdi on the tray has set for 24 hours now. I used Ditra-Set. It's sturdy under my whole palm, but I can easily push a divot into it with my finger. That concerns me. Most say flat pebble should be fine, though. I'm sure it would be fine with larger tiles, but can anyone comment who has done a flat pebble shower floor over a Kerdi Tray on how it's holding up.
Sam
Old 01-18-2012, 01:04 PM   #13
tulse
BTW, Schluter tech says it's fine to use flat sawn as long as fully embedded in thin-set and cured.
Also, what size trowel should I use?
Thanks.
Sam
Old 01-18-2012, 01:44 PM   #14
vrusso123
N. E. Ohio tile-setter
Sam, smallest notch you can and still get full coverage. probably a 3/16" v-notch, maybe 1/4" square. never installed pebbles over foam. show us a pic eh? how big are they? PLEASE let us know if it ever fails.
vincent
http://russotile.com
"just keep stickin' 'em" - Pat Reagan
vrusso123 is offline   Reply With Quote
Old 01-18-2012, 01:59 PM   #15
tulse
Sure, thanks.
Sam
Last edited by jgleason; 01-18-2012 at 02:48 PM. Reason: please use the paperclip icon and attach images
bathroom project fmfmedic Tile Forum/Advice Board 2 04-13-2011 02:14 PM
New bathroom project need help 2Panther Tile Forum/Advice Board 70 02-07-2006 05:47 PM
New Bathroom Project RyanM Tile Forum/Advice Board 12 03-06-2005 11:02 AM
Second Bathroom Project Todds Tile Forum/Advice Board 24 07-16-2004 02:57 PM
possible bathroom project bmiller Tile Forum/Advice Board 9 12-30-2002 08:03 AM
