Old 01-26-2004, 02:40 PM   #1
Glenn the tile guy
marble tile install
i am just going to make this as plain and simple as possible
is there any real difference between installing ceramic tile and marble or is it the same proccesses.
Glenn the tile guy is offline   Reply With Quote
Old 01-26-2004, 05:10 PM   #2
Hi Glenn,
The difference is in degree of tedium.
If it takes patience to do and excellent ceramic job, it takes ten times as much to conquer stone tiles.
Old 01-26-2004, 09:04 PM   #3
Jim H
Arkansas Tile Man
Hi GLenn,,Admire your interest in stone. You are dealing with a flat polished/honed surface and tiny grout joints, 1/16" or less and some are without a chamfered or beveled edge, (mostly travertine that is) just square saw cut. Zero forgiveness. Totally different ball game. Personally I like stone,,very challenging.
Jim H is offline   Reply With Quote
Old 01-27-2004, 05:39 AM   #4
tileguytodd
Official Felker Fanatic
tileguytodd's Avatar
Think Slow!!!
Doing a quality Stone installation is not for everyone.There are good ceramic installers that do not like doing stone work.
If your like a hunting Dog you have to run 5 miles before getting to the job site,perhaps Stone installs should be avoided.
Patience is not only a virtue,it is a requirement in Stone work.
You will not be practicing your standing around technique on a granite or marble job.
Prepare everything,then prepare it again.when you think its flat,it isnt so do it again.
And remember, never ever look marble directly in the eye until it is set with 100% coverage.if you do it will break.marble doesnt like to be looked in the eye
Old 01-27-2004, 12:09 PM   #5
doitright
doitright's Avatar
Hi Glen, Welcome
To make it simple in response:
Yes, but you need a tighter substrate (L/720 vs. L/360)
Yes, layout is critical, but tighter joints.
Yes, you can use thinset, but medium bed yields better results.
Yes, you grout, but you best use non sanded, and plan on regrouting while wet (due to sagging grout).
Throw it in, only if you want it to look thrown in.
If you've never worked with stone, pick a small room, and maybe best be in you're own house!
John Koessler
Old 01-27-2004, 02:37 PM   #6
Steven Hauser
STT Owner
Steven Hauser's Avatar
Yep Glen,
Everything the two John's, Todd and Jim said plus the fact that there are many different types of stones to install and many different installation or sealing needs to address.
Learn to do a shower first and stone second.
my .02
Steven
Clean
Sealed
Safe
STT Sealers with Attitude!®
