Old 01-26-2004, 11:28 AM   #1
remove grout & grout film from new ceramic tile floors
I need some advice for what acid or solution to use to remove grout and grout film from several new tile floors.
How should I protect the grout while cleaning the top of the tiles and then what kind of sealer should I use when finished to seal the tiles to a semi-gloss finish (which is the original finish of the ceramic tiles)?
JBraswell is offline   Reply With Quote
Old 01-26-2004, 02:10 PM   #2
I moved your thread to the Advice Board where it will get more attention.
Start out with 10% vinegar and water. Wet the area and let it sit for 10 minutes, then scrub with a stiff bristle brush. Rinse thououghly, then dry. If necessary, repeat with stronger concentrations (up to 50%). You may have to go with a stronger acid, shich you will find at your tile supplier. Be carefull, it is acid, after all. Don't forget to rinse thoroughly, since the acid can attack the grout and thinset.
If the tiles were simi-gloss, they will return to that condition after the haze is gone. You have only to seal the grout, which you can do with out grout sealer. Check out our on-line store. Wipe the entire surface, then buff the sealer off the tile surfaces.
