Old 12-24-2011, 11:42 AM   #1
Kerdi and drywall mud
Ideally, your shower area is virgin drywall. But, what do you do if the builders mudded the whole area? Schluter says prime it with a laytex primer, but doesn't give any recommendations. What should one use that has been tested and reliable? The danger of going directly over the mud is it could soften and you might end up with a debonded area. personally, I don't think it would be a big deal as it would reharden, and probably then never get wet again, but the what if scenario could come into play, especially if a large area was skimmed out with the non-hardening stuff.
Longtime lurker, avid DIY'er
Old 12-24-2011, 12:10 PM   #2
jgleason
Moderator - Theatre Guy (and computers)
jgleason's Avatar
I would use the latex-based Kilz on the joint compound, wait a day and then install the Kerdi.
jgleason is online now   Reply With Quote
Old 12-24-2011, 02:29 PM   #3
doitright
Tile and Stone Contractor -- Moderator
doitright's Avatar
Hi Jim
Zinsser also has some great primers. You can pick one from here.
John Koessler
Koessler Enterprises
NTCA, MIA, SFA
doitright is online now   Reply With Quote
Old 12-24-2011, 02:30 PM   #4
I like the Zinsser oil based that dries in one hour and can be latex'ed over great stuff
Paul
Old 12-24-2011, 02:55 PM   #5
eurob
tile and stone installer
eurob's Avatar
Jim,
Thinset mfgs will recommend you the right primer to apply on the drywall mud , prior to the thinset.
As an example , Mapei recommends Primer L --- 1 part primer and 3 parts water ratio --- to be applied over gypsum products . Planicrete AC --- 1 part AC and 1 part water ratio --- if I remember correctly , is also recommended .
Give them a call , I am pretty sure they have a primer for your application .
P.S. We don't recommend the tiled areas to be drywall mudded , but who listens to us .
drywall/Kerdi vs cbu/mud pan mjungdahl Tile Forum/Advice Board 3 11-30-2006 11:37 PM
drywall mud tunafish Tile Forum/Advice Board 14 07-24-2006 10:18 PM
What was the final decision of Kerdi over drywall mud Kirk Grodske Professionals' Hangout 7 04-22-2006 04:44 PM
Non Mud: All Kerdi & Ditra Bath on ply, 2x4's greenboard & drywall Dale Moore Tile Forum/Advice Board 139 02-28-2006 06:18 PM
Kerdi and drywall mud peterd Tile Forum/Advice Board 2 07-14-2004 07:10 AM
