Old 11-03-2011, 11:46 AM   #1
TEC Power Grout
I see Tec is introducing a new grout called power grout supposed to be out in a week or so. Thoughts? Anyone test it?
www.tecpowergrout.com
Old 11-03-2011, 04:45 PM   #2
probably just some repackaging.
I'm happy with Laticrete PermaColor grouts.
TEC isnt big down here and only a few places stock it.
Old 11-03-2011, 04:59 PM   #3
tileaz
My guys tested this grout a few months ago. I have seen it in action. Easy to spread, product data sheet says no need to be sealed, never have seen that in writing before. I have already submitted the grout for two commercial projects here in Phoenix, can't wait to see it on the jobs.
tileaz is offline   Reply With Quote
Old 11-03-2011, 05:25 PM   #4
so is this a relabeled and improved AccuColor XT ?
Old 11-03-2011, 05:44 PM   #5
Levi the Tile Guy
Tile and Stone Contractor
Levi the Tile Guy's Avatar
Don't know, but it looks like you have to mix it with something. That is just a speculation but in the pic it shows a little container by the bag. I tried to call my TEC rep but he didn't answer.
Levi The Tile Guy
Old 11-03-2011, 08:10 PM   #6
I saw my rep last night, the little container is a 5 lb jar. They will have it in 5 lb jars, 10 lb bags and 25 lb bags. I see the jar not making it. But I had the sheet on it, you dont need to mix it with a drill just a margin trowel like prism.
It has nothing to do with the Accucolor XT totally new product.
Old 11-04-2011, 04:30 PM   #7
Mike K.
TEC Power Grout
Wow! Great news travels fast!
Power Grout IS a brand new formulation of grout from TEC and H.B. Fuller Construction Products. It combines the easy-to-use features of regular cementitious grout with many of the advantages of epoxy and urethane grouts. So you get fast, trouble-free installations with permanent stain resistance, crack resistance, perfect color consistency and no efflorescence. When I say itís fast, I mean open to traffic in 4 hours and 24 hours for showers.
Itís simple Ė just mix it with water and install. No sealing needed either, so it saves you time!
And itís far less expensive than epoxy/urethane grouts!!
Mike,
TEC/H.B. Fuller
http://www.tecspecialty.com
Mike K. is offline   Reply With Quote
Old 11-04-2011, 04:37 PM   #8
Levi the Tile Guy
Mike,
I would assume you are affiliated with TEC, correct?
Levi The Tile Guy
Old 11-04-2011, 04:38 PM   #9
Hi Mike,
you work for TEC ?
you sound like a rep to moi.
Old 11-04-2011, 06:39 PM   #10
Mike is products manager for H B Fuller/TEC.
Old 11-04-2011, 07:00 PM   #11
well cx should get after him for his lack of signature line.
Old 11-05-2011, 12:42 AM   #12
Higher Standard Tile
Higher Standard Tile's Avatar
This is what I got emailed to me.
Originally Posted by TEC Rep
PLEASE DO NOT MISTAKE THIS FOR ANOTHER STANDARD GROUT HERE ARE THE HIGHLIGHTS
NEW PLASTIC BAGS
COLOR CONSISTENT FORMULA
UNIVERSAL FLOOR OR WALL GROUT (1/16 TO 1/2") REDUCES YOUR INVENTORY BY 50%
PERMANENTLY STAIN RESISTANT (Unlike all other competitors standard or Hybrid cement based grouts THAT recommends additional sealers)
EFFLORESCENCE FREE
CRACK FREE
FAST SET (Allows traffic in 4 hrs)
EXTENDED POT LIFE (60 min.)
SHOWER USE AFTER 24 HRS. YES 24 HRS! ! ! ! NOT 7-10 DAYS LIKE CEMENT GROUTS OR URETHANES
EASIER TO USE THAN URETHANE OR EPOXY GROUTS
LOWER COST OF USE!
HYBRID CEMENT GROUTS (Upgrade cost of $0.08 psf) Low stain resistance, added sealer required
POWERGROUT (Upgrade cost of $0.15 psf) No need to seal
GROUTBOOST PRO (Upgrade cost of $0.19 psf) No need to seal. ALSO PROVIDES PERMANENT OIL BASED RESISTANCE
URETHANE GROUTS (Upgrade cost of $0.55 psf) PLUS ADDED LABOR COSTS
EPOXY GROUTS (Upgrade costs of $1.00 psf) PLUS ADDED LABOR COSTS
Dan Fisher, CSI, CDT
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Old 12-27-2011, 01:30 PM   #13
Kathy :)
Never needs sealing?
Product data sheet for AccuColor XT also states,"Highly stain resistant, never needs sealing." Please weigh in if you've found this to be true or not and if the same can be said of Power Grout.
Kathy
Kathy :) is offline   Reply With Quote
Old 12-27-2011, 01:59 PM   #14
tileaz
Kathy, we are using the new Power grout in an installation outside of Tucson in an elementary school. The architect was impressed with the language in writing on the data sheets that said this grout never needs sealing. It is about half the cost of epoxy grout. We will start grouting next week. I can update you on the usage if you want.
Old 12-27-2011, 09:05 PM   #15
stile45
Thumbs up new tec grout
Hi guys I just installed that grout in a job last Friday . I use mostly Permacolor for awhile now .The previous X T from Tec was not to my liking.It was fine to work with, good potlife and good color retention . More gritty then Permacolor but I liked it , I would use it again.
scott
stile45 is offline   Reply With Quote
solar power plants in Spain produce power at night lati_cz The Mud Box 4 04-20-2010 04:53 PM
tec invision grout bkelley77 Tile Forum/Advice Board 2 08-29-2009 05:57 PM
New Tec XT grout pitterpat Professionals' Hangout 2 10-11-2006 08:15 PM
Tec Grout Additive figaro Tile Forum/Advice Board 1 08-24-2006 09:56 PM
Power grout saw? gastephens Tile Forum/Advice Board 7 07-26-2003 06:48 AM
