Old 09-19-2011, 03:51 PM   #1
Seawulff
Where to start tile with Kerdi system
I am a DIY trying to remodel a shower that was leaking. I have dismantled the whole thing and have decided to use the Kerdi system. They recommend starting the tile from the bottom instead of using a mid starting point with a ledger board. How do I prevent having a partial tile at the ceiling using this method. Is there a better way to do it? I also am going to try to use a Fin Pad niche any suggestions on this are helpful too. Do I need to use bullnose tile along the edge of the niche or just leave the junction of the tiles "squared off". Thanks in advance.
Chris
Chris
Seawulff is offline   Reply With Quote
Old 09-19-2011, 04:19 PM   #2
Lazarus
Lazarus's Avatar
A "Ledger Board" is a good way to start. Lay out your tile on the floor, with spacers. Figgure where the top tile will/should be. We are assuming that the ceiling is level. Measure down to where the last tile (cut or not) is placed and nail up your ledger board there.
At this point, you SHOULD be able to lay your tiles all the way up to the top.
Do all the walls. Now, do the floor. Now, custom cut the bottom row of tiles to fit. Grout that puppy. Have an adult beveridge and admire your work!
Laz...
Old 09-19-2011, 04:29 PM   #3
If you nail or screw a ledger board, you'll want to either repair the holes with a with a square of Kerdi (or Kerdi-band) or a dab of Kerdifix. If you're not going to the ceiling with the tile and the pan/wall edge is nicely level, you could start at the bottom and work up. Most people have the floor tile end underneath the wall tile, but, if you are neat, you could do it the other way as well. I think having the floor tile go underneath the wall tile is neater, and that means being much more careful getting that bottom row perfect. Often easier to do the floor, then finish that last bottom row. Cut it if needed.
Most tile don't look that great on their edges. Bullnose, or possibly backmitering (leave the original small round-over intact), or an edge profile (Schluter makse some), or even possibly a contrasting quarter-round. If it is a through-body unglazed porcelain, you could round it over and even polish it, but if it is glazed, you have far fewer options.
Old 09-20-2011, 06:18 AM   #4
WendyHMN
Amateur Jack of All Trades
WendyHMN's Avatar
I just want to add that if you're like me, your ceiling is not completely level. You actually want to plan to have a cut tile there. That way you can match the cuts to the line of the ceiling and any slope won't show.
Wendy
Old 11-01-2011, 09:24 PM   #5
Seawulff
Kerdi and Densshield
I am new to the forum and the shower install game. I am redoing a leaking shower and might be over engineering this to prevent leaks in the future. I have installed DensShield on the walls and purchased a Schluter shower kit and plan to install the Kerdi membrane over the DensShield with the Schluter base, curb and drain. Are there any issues installing the Kerdi membrane on the DensShield? I plan to use unmodified thinset as recommended. Thanks in advance.
Chris
Chris
Old 11-01-2011, 10:41 PM   #6
dhagin
Hi Chris,
Please keep all your posts about this project in this thread so folks can see what you're workin on, and what's been previously asked and answered. We can give the thread a more generic title if you want, just ask. Thanks.
Well, you have a conflict with DensShield and Kerdi. The installation instructions for DensShield require modified mortar over it, and the install instructs for Kerdi require an unmodified under it.
With DensShield up already, I'd use a liquid waterproofing to go over the nail/screw heads and corners - something like Laticrete Hydro Ban or Custom Building Products Redgard. Either of these can be used with a Kerdi Drain.
Read and follow all instructions for using the liquids, especially relating to thickness of the membrane. Use a wet film gauge to measure the coat thickness. You can get the wet film gauge at a good paint store, not a box store.
dana
Old 11-04-2011, 11:54 AM   #7
Seawulff
Sorry about the confusion I didn't realize that the threads got connected somehow. I did call Schluter and they said it was ok to use the Kerdi on DensShield with thinset so now I am more confused than I was before.
Chris
Old 11-06-2011, 03:18 PM   #8
dhagin
You might send a follow up email to Schluter asking what mortar to use to attach Kerdi to DensShield, and how long to wait til you can set tile over it.
We'd be interested in the written response.
dana
Old 11-17-2015, 09:33 AM   #9
ninjaryder1st
Follow up
Was there ever any written correspondance from Schluter on mod/unmod mortar use for kerdi band on Densshield?
I'm looking to use Kerdi Shower Valve seal (needs mortar) over the valve and shower head areas of Denshield.
If unable to use this, what else can be done to seal the circle shower head hole of pipe, and square shower valve hole areas of Densshield?
Thanks all!
J
J
ninjaryder1st is offline   Reply With Quote
Old 11-17-2015, 01:00 PM   #10
Use either an unmodified thinset, or a rapid-setting modified. Otherwise you can use silicone to fill the gaps.
For other questions you may have regarding your project, feel free to start your own thread.
Kerdi over DensShield Scotvl Tile Forum/Advice Board 5 12-09-2010 05:16 AM
DensShield Rd Tile Professionals' Hangout 16 02-16-2008 09:25 PM
What do you think of DensShield? Oebur Tile Forum/Advice Board 5 08-03-2007 10:34 AM
'Densshield' better than Kerdi?? stfo Tile Forum/Advice Board 16 08-17-2006 02:18 PM
Kerdi and DensShield Unregistered Tile Forum/Advice Board 1 11-10-2004 01:57 PM
