Old 08-30-2011, 12:07 AM   #1
Hardwood floor install question
I know this is a tile forum, but I imagine people on here will know, or will be able to recommend a forum for hardwoods. I came here because I've used this site for 2 bathroom tile jobs and I know the people on here can be trusted. Here's my question.
I have an older 1920's Spanish home with 3/4 inch thick planck subfloor. I think they are 6 inches wide. The planks run perpendicular to the joists. Some people have told me that hardwood floors should also run perpendicular to joists, but I think it my case this is just wrong. It seems that the hardwoods need to run perpendicular to the plank subfloor. Isn't this correct?
A similar issue: If I am correct about the direction of the hardwoods, but wanted, for aesthetic reasons to run the planks in the opposite direction, I imagine it would be fine to put down a layer of something on top of the plank subfloor, prior to the hardwood install. In order to not get too much of a height mismatch with the tiled bathrooms, and to keep costs down, I would like to use 3/8 inch thick OSB. I know, I know OSB is a bad word. But, since I already have 3/4 inch planks, it should be plenty strong. I just need the OSB to allow me to change the direction of the hardwoods. Can anyone tell me if this is reasonable and OK? Or can someone point me to a more relevant forum?
TonyB is offline   Reply With Quote
Old 08-30-2011, 11:02 AM   #2
Tony, OSB is not a "bad word" in subflooring applications. Some of it is quite usable. I would still use plywood in your application.
Here are a couple wood flooring sites that have been recommended over the years. I know nothing about either site:
Hardwood Flooring Guide.
Hardwood Flooring Talk.
hardwood floor question lati_cz Professionals' Hangout 19 05-24-2010 06:42 PM
Hardwood Install Question sportskid1 Tile Forum/Advice Board 10 04-07-2009 10:05 AM
hardwood floor over concrete question jeb Tile Forum/Advice Board 3 09-06-2007 05:43 PM
install ceramic directly over hardwood? jmteck Tile Forum/Advice Board 5 11-03-2004 11:17 AM
Hardwood floor (not tile) question Kurt M. Tile Forum/Advice Board 10 10-23-2004 12:34 PM
