Old 07-19-2011, 02:10 PM   #1
noreallyno772
How to clean Stains on Laticrete SpectraLock Grout
Hi Guys,
I have a rent house that has Spectralock grout, originally a very light yellowish color, that is just horribly "stained". After 5 minutes of scrubbing I was able to clean about 6" worth. It never did get back to the original color, just a dirty looking lightish color.
Is there any product that will clean this up? I have heard that an oxy-bleach type of product might help.
If cleaning fails, is it possible to put a thin layer of Spectralock on top of the existing grout? The top of the grout is ~1/32" to 1/16" below the tile surface. is that enough depth to get a layer to stick?
thanks,
Fred
Fred
noreallyno772 is offline   Reply With Quote
Old 07-19-2011, 02:25 PM   #2
Floorlifer
doing Floor to life.
Fred,
There are some quality grout and tile cleaning products on the market. Look into Aqua Mix Heavy Duty Tile and Grout cleaner, I've gotten great feedback with this product. If all else fails, you could consider a grout colorant and sealer. You could even get the same Laticrete color and re-color it. This route would help prevent stains from re-appearing in the future
Lance
www.floorlife.com
Lance
www.floorlife.com
Floorlifer is offline   Reply With Quote
Old 07-21-2011, 12:50 PM   #3
hbrothberg
hbrothberg's Avatar
Cleaning Grout .....
Some comments from our technical support team:
"Usually a bleaching type cleanser (e.g. soft scrub with bleach, Clorox clean-up, etc..) with a scrub pad / brush. Typically, routine mopping will not get down far enough into the grout joint to actually lift up the dirt / soil."
From our literature:
ROUTINE MAINTENANCE
LATICRETE SpectraLOCK PRO Grout is stain resistant when properly installed and allowed to cure properly. It is, unfortunately, not self-cleaning. Routine maintenance can be done with detergents and a sponge or mop. For tough or difficult to remove soil, a bleaching cleaner (e.g. Soft Scrub, Comet, Ajax, etc. or electric dishwashing detergent) on a nylon scrubbing pad or a long handled stiff bristle brush can be used. Please note: Prior to using any cleaning material on a tile, etc. installation, test a discrete area or scrap piece of tile to insure desired results.
Also ....
Take a look at the attached.
Henry
Henry Rothberg
hbrothberg@laticrete.com
www.laticrete.com
Office: (203) 393-0010 ext 202
Cell: (203) 988-1814
Full Disclosure: I am a 2nd generation Laticrete guy !
Follow my Blog: www.laticrete.blogspot.com
hbrothberg is offline   Reply With Quote
Old 07-22-2011, 02:06 PM   #4
35Anderson
35Anderson's Avatar
any type of bleach based product should help tremendously.
Thomas
35Anderson is offline   Reply With Quote
Old 07-24-2011, 08:12 AM   #5
doitright
doitright's Avatar
Hi Fred, Welcome!
What were you using to attempt cleaning?
Can you post a photo?
Usually a tile & stone specific high alkaline cleaner will do the trick. It's very important to allow the product to dwell on the surface of extremely soiled surfaces for at least 10 minutes. It is essential to not allow the product not to dry on the surface, which would require reapplication.
Agitation with a stiff bristle brush will also promote premium results.
Removal of the dirty solution with a wet vac will facilitate cleanup, as well as minimize spreading of the soil.
Rinsing may or may not be necessary, depending on the products dilution.
I have used grout colorant on SpectaLock, with successful results. The key will be the epoxy will still need to be thoroughly cleaned beforehand. If you decide to go this route, I strongly suggest to perform a bond TEST before doing the entire area.
John Koessler
Keeping a tile shower clean, and removing stains from floor grout RaymondJ Cleaning, Restoration and Sealing 2 04-01-2011 08:54 AM
New tiles/Spectralock grout... How to clean? Madam Tile Forum/Advice Board 1 02-18-2010 11:31 AM
clean grout stains off limestone tile diomed Tile Forum/Advice Board 2 07-06-2006 10:57 AM
Have you heard of SpectraLOCK grout by Laticrete? Tile_Andy Tile Forum/Advice Board 1 10-10-2004 07:05 PM
Laticrete SpectraLOCK Grout yvonne_r Tile Forum/Advice Board 3 10-07-2003 06:40 PM
