Welcome Sabrina.
Typically, the tile contractor supplies those items based on a number of installation details, budget, etc... I'm curious why they would task you with something like that?? The most important part to a lasting tile installation is what's behind the tile; the stuff you don't see after it's installed. And there are many options for mortar and grout as well.
Originally Posted by Sabrina
I need non sanded grout for 280 square feet and also thinset for drywall for the 280 square feet. The tile will be 6x6.
-is the surface of the walls bare drywall, with no drywall finish?
-is any of this within a wet area like a tub/shower or shower?
-what is grout joint width?
-what is the pattern?
I need sanded grout for the floors and a thinset for wood for 940 square feet. The tile is 20x20.
-you're setting over a wood floor and not concrete?
could you tell us a little about the floor construction and prep?
-what is the size, spacing and maximum unsupported span of the joists?
-what layer or layers of plywood or wood are above the joists and how are they installed?
-what material is directly below the tile & thinset?
-what is the grout joint width?
-is this tile porcelain or soft bodied ceramic or ?
You may be just fine with all the prep for both walls and floor, I hope you don't mind wanting to verify first.
...and what CX said too...
