Old 07-10-2011, 11:01 AM   #1
FJK
corner bead for drywall/cement board corner
Somehow, this has turned into an issue that I don't know the solution. Due to health problems, I had to start hiring guys to finish a bathroom remodel I was doing myself. The tile guys say this out of their scope of work, which I accept.
I had a painter finish off the drywall in my bath & he did a good job with the exception of an outside corner, where cement board on 1 wall met drywall on the other wall. He didn't install any outside corner bead. We have been using the paper/metal bead that is held on with drywall mud. Obviously, this won't work on cement board. What is the best way to install corner bead in this situation & what type of corner bead should be used? I need to get this resolved before the tile guys get scheduled in about a week.
Thanks, Jim
Jim
FJK is offline   Reply With Quote
Old 07-10-2011, 11:03 AM   #2
Jim,
Is this outside the wet area? If it is, you can use the paper / metal tape on the corner. Just keep the drywall mud out of the wet area, which can be easily accomplished by masking off the area. You can tile over and / or waterproof over the drywall mud.
How is your shower being waterproofed?
Old 07-10-2011, 11:17 AM   #3
FJK
The cement board is on the wet area, the drywall is on the dry area, forming an outside corner. Are you saying just use the metal/paper corner bead, install with drywall mud, even on the cement board. Then, just tile over the mud with thinset & tile.
Jim
Old 07-10-2011, 11:27 AM   #4
Jim,
So you're saying the last 1" corner of the cbu at the drywall will get wet? is this a tub surround? is there a shower door?
Old 07-10-2011, 12:24 PM   #5
FJK
Yes, it is a tub surround. So, the first 1" of cement board at the corner, is outside the tub. Since it is outside the tub, I guess you could say that 1" of cement board is in a dry area.
Jim
Old 07-10-2011, 12:42 PM   #6
tiletime56
Shaun Haley Tile
tiletime56's Avatar
Send a message via Skype™ to tiletime56
Can you cut the cement board back?
Shaun
https://www.facebook.com/lists/22363...e/172655561618
Luv fat mud!
tiletime56 is offline   Reply With Quote
Old 07-10-2011, 12:54 PM   #7
FJK
It would be a major pain to cut back the cement board at this point & replace it with about an inch of drywall. The tile (bullnose) will run to the outside edge of the corner anyhow.
Jim
Old 07-10-2011, 12:59 PM   #8
Then you have 3 options:
A- tile the drywall outside the shower as a "picture frame" type installation
or
B- use L channel where the L channel is normal sized on the attachment side and 1/2" on the bottom L side, which tucks under the tile. Thatway there is no floating on the CBU side.
or
C- Use J channel putting the attachment side on the drywall, where the tile overlaps the bottom of the J channel
Old 07-10-2011, 01:10 PM   #9
mossypath
mossypath's Avatar
I will never use a metal corner bead on a corner of a tub wall .
look at the plastic Tear Away L Bead http://www.trimtexinc.com/product_ca...egory&catid=28 if you are going to tile to the corner . It will give you a nice edge to finish to without bumping out the corner for your tile install . works great for soffits above tubs to.
I will always use plastic if water will be anywhere close to the trim. I cant tell you how many corners I have seen rusted out near the floor from water being splashed on the bathroom floor and wicking up the drywall.
Tammara
Understand that holding the media accountable is just as important as holding government accountable.
"freedom of the press is guaranteed only to those who own one." A.J. Liebling
‘Water and air, the two essential fluids on which all life depends, have become global garbage cans.’ Jacques-Yves Cousteau
mossypath is offline   Reply With Quote
Old 07-10-2011, 01:21 PM   #10
handymikey
That's a great idea Tammara. I've used that product myself and it worked out very well. I wouldn't hesitate to use it for this application.
handymikey is offline   Reply With Quote
Old 07-10-2011, 01:26 PM   #11
FJK
From C&R's options, I don't want A, so it looks like B or C. The post following C&R's also says use an L channel. Where I can I locally get this L channel? It sounds like the L channel has 1 leg the normal width of a corner bead & the other leg is short, like 1/2" to cap the edge of the drywall. Am I understanding this correctly? Also, this L-channel is all plastic, so it is just installed with drywall mud?
Jim
Old 07-10-2011, 01:33 PM   #12
You can buy plastic L bead at home burrito, or lowes, or a building supply store. Its fairly common.
Instead of installing it with screws or nails or just mud I prefer to install it with Corner bead adhesive spray (aka contact adhesive) as this does not deform the plastic, gives a nice straight edge and you can use a long level when installing it.
corner bead? lefty33 Tile Forum/Advice Board 3 02-11-2009 06:02 AM
Large corner gaps between installed cement board jackcracker Tile Forum/Advice Board 4 02-25-2008 06:10 PM
How to finish corner where cement board meets greenboard? rmx2501 Tile Forum/Advice Board 3 08-18-2006 01:03 PM
corner bead lisaA Tile Forum/Advice Board 18 11-06-2005 10:49 AM
Corner Bead and Cement Board kidtricky Tile Forum/Advice Board 3 07-07-2005 01:58 PM
