Old 07-10-2011, 09:25 AM   #1
rossow (mn)
Subfloor thickness for Ditra?
I have never used Ditra and need advice. Assuming framing provides adequate protection against deflection, am I correct that I can apply Ditra over 3/4-inch T&G glued-and-screwed plywood subfloor, then 1/4-inch 12x12 ceramic tile over the Ditra? I'm from the old school that learned subfloor under tile should be at least 1-1/8" thick (e.g., 3/4 + cement board). Does the isolating function of Ditra let me get by without the cement board (again, assuming subfloor/framing meet deflection standards)? Ditra seems too good to be true in helping keep floor thickness down where new floor butts against old floor in an addition. Am I off-track here? Please advise.
rossow (mn) is offline   Reply With Quote
Old 07-10-2011, 09:43 AM   #2
Welcome back, rossow (mn). Please put a first name in a permanent signature line for us to use.
Gotta be a really old school. Never been such a requirement that I'm aware of. Lotta misconceptions out there about it, though.
The subflooring requirement for use with any CBU is specified by the CBU manufacturer, and is generally specified using their thinnest material. Use of half-inch CBU (or thicker) is indicated only when it's desirable to raise the tile installation. The subfloor requirement remains the same.
...am I correct that I can apply Ditra over 3/4-inch T&G glued-and-screwed plywood subfloor, then 1/4-inch 12x12 ceramic tile over the Ditra?
That would depend upon your joist spacing. If you'll go to the Schluter website, you'll find their requirements for the use of Ditra in most any common subflooring situation. Their instructions are usually very clear.
Ditra is not too good to be true, it's simply a higher-tech replacement product for more traditional CBU underlayments. Still requires the same joist deflection and subflooring considerations as other such products. And it's easier to use than most.
Ditra Thickness Craigsproject Tile Forum/Advice Board 3 10-27-2010 03:39 PM
subfloor thickness slapappy Tile Forum/Advice Board 2 10-08-2007 08:48 PM
Thickness of Ditra VirtualThought Tile Forum/Advice Board 9 07-15-2006 09:46 PM
thickness of subfloor? Ased Tile Forum/Advice Board 4 03-23-2006 06:47 AM
Subfloor Thickness kmwhitt Tile Forum/Advice Board 1 05-11-2005 08:50 AM
