Old 05-30-2011, 10:23 AM   #1
Big Randy
Black marks
So I have been tiling my new bathroom. Finally got all the tile set and start the grouting process. Well as were cleaning the grout off the tile I find that there are some places were the rubber float left black marks on the tile. These marks are not coming off. I need help...
Big Randy
Big Randy is offline   Reply With Quote
Old 05-30-2011, 10:30 AM   #2
Tiletim
Lost in the details
Tiletim's Avatar
These work great! and cheap too
Tim
Tiletim is offline   Reply With Quote
Old 05-30-2011, 10:21 PM   #3
Big Randy
Cool Black marks
Still no luck I have tried Mr Clean Magic Erasor, Scotch brite, Goof off, Acatone, and nothing is gettin it done. Any other ideas out there? I cant be the first one that this has happened to. Black marks from a black rubber grout float.
Big Randy
Old 05-30-2011, 11:52 PM   #4
Hi Randy,
What kind of tile is this?
Old 06-01-2011, 09:56 PM   #5
Big Randy
The marks are on three types of tile ceramic, Porcelain, and stone.
Big Randy
Old 06-01-2011, 10:04 PM   #6
silvercitytile
silvercitytile's Avatar
my friend tile joe uses Bar Keepers Friend. i dont have a link sorry
Castillo Construction
Old 06-01-2011, 10:40 PM   #7
Shaughnn
Trowel Monkey
Shaughnn's Avatar
hi Randy,
If you've tried all of that, then it's not a mark left by the rubber of the float. Does your grout float have a metal backing plate on it, by chance? Your "black marks" could very well be transferred aluminum, in which case Barkeeper's Friend could very well be your solution. Be very certain to test all of the surfaces first though, as this cleanser is acidic and can alter the finish of the tile if you aren't careful.
Best of luck,
Shaughnn
Old 06-01-2011, 10:54 PM   #8
silvercitytile
Thanks Shaughnn
Old 06-02-2011, 03:44 AM   #9
Davestone
Florida Tile & Stone Man
Barkeepers friend may etch the stone,you may need to wipe the whole stone to keep it uniform.If it is a physical mark that will work, if it's a chemical mark mek should work.
http://Davestonestile.com
Old 06-03-2011, 01:09 PM   #10
vrusso123
N. E. Ohio tile-setter
sounds like metal marks. you can try Soft Scrub. test on scraps first, i have never used it on natural stone.
vincent
http://russotile.com
"just keep stickin' 'em" - Pat Reagan
vrusso123 is offline   Reply With Quote
30 yr old black slate with dirty black grout cbell50 Cleaning, Restoration and Sealing 4 11-22-2009 07:25 PM
Saw marks Bruins Tile Forum/Advice Board 6 05-21-2009 04:21 AM
Black grout is grey, not black.... Duane903 Tile Forum/Advice Board 24 04-28-2008 08:53 PM
Black Slate and Black Grout question Chloe B Cleaning, Restoration and Sealing 3 02-25-2006 07:18 AM
Installed black granite tile... need black caulk or flexible filler alkon Tile Forum/Advice Board 6 04-03-2005 09:24 PM
