Old 04-28-2011, 10:43 PM   #1
SteveSNJ
Backsplash tile of different thicknesses
I am a DIYer preparing to tile a bathroom backsplash. I am going to use a row of 4x4 travertine tiles and then some glass/stone mosaics above them. The travertine is about 1/16" thicker than the mosaics, so I am wondering how to compensate for this so that the difference is not noticeable. Is there anything that I can use behind the mosaic tile to bring it out 1/16"?
I could try to compensate with thinset thickness but don't feel confident trying this approach.
Thanks for any advice.
Steve
SteveSNJ is offline   Reply With Quote
Old 04-29-2011, 12:38 AM   #2
Jhereg
Signature Tile - Owner
Jhereg's Avatar
hit home depot and grab some easymat and install behind your mosaics.
Chad N. owner
Signature Tile - Renton, Washington
www.signaturetile.net (a work in progress)
Jhereg is offline   Reply With Quote
Old 04-29-2011, 04:56 AM   #3
tileguynky
Here is a pic of a kitchen backsplash that I did recently. I had a similar thickness difference, glass and handmade tile. I built out the glass section with some extra Ditra that I had left over. The Easy Mat will work too.
Old 04-29-2011, 07:50 AM   #4
SteveSNJ
Thanks for the help!
Steve
Old 04-29-2011, 05:21 PM   #5
SteveSNJ
Greg, In the photo you posted, how do you handle the face plates for the electrical outlets to avoid having a gap between the plate and the wall?
thanks
Steve
Old 04-29-2011, 06:18 PM   #6
tileguynky
That pic is showing the dirt in location. After glass was installed on the dirt, there was another liner stacked on top (was stopped on each side of outlet cover). Then the rest was the 3x6 field tile. By building out the glass, the covers set flush with both surfaces. That was the reason that I built out the glass. Here is a pic of the finished backsplash.
Old 04-29-2011, 06:27 PM   #7
ChristensenTile
Tile Professional
At that difference I'd probably try to do it with thinset because it simply isn't that hard. Also, its much harder to deal with the mosaic being thicker than the field tile....versus all the examples in this thread. But even then, there is always a solution.
And outlets are the worst part about doing backsplashes. Without them they would always be the easiest jobs in the world, but because of them they can be a real pain. Some mosaics have variable heights in the actual pieces, and these just dont look good around outlets because you end up with gaps. Still, no matter what, there is always a solution to this stuff. Yours seems to be relatively simple compared to what it could be.
Case Christensen
Wisconsin Tile Installer
ChristensenTile is offline   Reply With Quote
Old 04-29-2011, 06:52 PM   #8
SteveSNJ
Thanks for the advice. The finished backsplash looks good !
Steve
Two different tile thicknesses? pavlovcat Tile Forum/Advice Board 5 01-29-2008 09:27 PM
Different tile thicknesses Davery Tile Forum/Advice Board 8 01-28-2007 07:42 PM
Tile with different thicknesses MPC Tile Forum/Advice Board 1 02-10-2006 09:14 AM
different thicknesses of tile lornab The Mud Box 10 06-19-2004 07:27 AM
backsplash - different tile thicknesses jackrterrier Tile Forum/Advice Board 31 03-19-2003 07:30 PM
