Old 04-05-2011, 07:04 PM   #1
Skunkboy
4x8 Hardi-backer for shower?
I'm putting in a new bathroom in my basement. I installed a 34" x 48" shower pan and I'm going to put 1/2" Hardi-backer on the walls of the shower. I see that they make Hardi-backer in 4'x8' sheets but I can't find it anywhere, it sure would be nice to have less pieces to put up and less seams. Does anybody do this, or do they just use the 3'x5' sheets?
Also, would you butt the flat and corner seams up tight or do you leave a gap?
Thank You!
Mark
Skunkboy is offline   Reply With Quote
Old 04-05-2011, 07:08 PM   #2
muskymike
muskymike's Avatar
Hi Mark, welcome! Why not use Kerdi? You can use drywall to put it on comes in 4x8 sheets.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
Old 04-05-2011, 07:16 PM   #3
Skunkboy
I guess it seems everybody is using the cement backer board these days, it seems more durable. Do you use the green board under the tile?
Mark
Old 04-05-2011, 07:19 PM   #4
muskymike
muskymike's Avatar
Hi Mark, no, I use regular drywall then Kerdi. I have been doing it that way for the last 8 years.
Musky Mike
Corrado Custom Tile
Old 04-05-2011, 07:23 PM   #5
Welcome, Mark.
MMike is suggesting you use gypsum board on your shower walls only if you use his suggested waterproofing method, i.e., the Kerdi Shower System.
No one here will recommend you tile directly to any such board, including "green board" in any wet area.
You say you've "...installed a 34" x 48" shower pan and..." Does that mean some sort of pre-made receptor that's finished, a pre-made receptor that requires tile, or a traditional mud/liner/mud shower pan? Whatcha got?
Homer can get you 4x8 sheets of Hardibacker, by the way. But that stuff is not easy to handle in that size.
Old 04-05-2011, 07:31 PM   #6
Skunkboy
Thanks for the welcome guys!
I'm using a Sterling finished shower base that is made out of Vikrell (I think that's what it's called), then the wallboard overlaps the edges. If it makes any difference I'm using 12"x12" tiles.
Thanks for all the advice.
Mark
Old 04-06-2011, 11:11 AM   #7
Skunkboy
Anybody else have any input/advice?
Thank you
Mark
Old 04-06-2011, 11:21 AM   #8
jgleason
Moderator - Theatre Guy (and computers)
jgleason's Avatar
You can use USG's Durock Next Gen, it comes in 4x8 sheets.
Old 04-06-2011, 11:24 AM   #9
WendyHMN
Amateur Jack of All Trades
WendyHMN's Avatar
Just use the small sheets unless you have some large friends to help lift. That stuff is heavy, especially when you're maneuvering it up stairs.
Wendy
Old 04-06-2011, 11:30 AM   #10
Skunkboy
Ok, That's what I was wondering, if most people just use the 3'x5' sheets. Do you leave a gap at the butt and corner seams, or butt them up tight to each other. I know your supposed to use the special fiber mesh tape and mud the seams
Mark
Old 04-06-2011, 11:42 AM   #11
Mark, you really wanna read and follow the instructions for the particular product you intend to use. They're pretty similar much of the time, but there are differences.
If you didn't get any instructions with your product, most of'em have all their information online. Some are better than others about that, but you can usually find'em.
My opinon; worth price charged.
Shower Walls: Green Board or Hardi Backer MaxxFusion Tile Forum/Advice Board 48 04-27-2011 08:11 PM
Hardi-backer On Shower Walls MATT9 Tile Forum/Advice Board 1 06-18-2008 01:46 PM
Hardi Backer Shower ceiling? Donnie McCool Tile Forum/Advice Board 3 08-04-2007 11:11 AM
Problem with installing hardi backer board in shower pchidel Tile Forum/Advice Board 8 07-12-2005 12:35 PM
just finished shower and have a problem. and hardi backer ? Unregistered Tile Forum/Advice Board 3 08-03-2004 08:11 AM
