Old 03-26-2011, 01:33 PM   #1
figaro
Shower seat dimensions
I need to build a corner shower seat and am having to work around a tile design somewhat. So I was wondering if you guys had a prefered or minimum dimension for a corner seat that you work with that enables a person to actually sit on the seat. Thanks.
Figaro
figaro is offline   Reply With Quote
Old 03-26-2011, 01:44 PM   #2
Fig,
The bench height when finished should be 17" from the shower floor to the top of the bench.
Normal depth is 12" as most people don't sit all the way back on a shower bench and only use the edge. You can make the bench deeper if the shower users are ...um... ehhh... need more room to work with.
Old 03-26-2011, 01:46 PM   #3
Cain
Cain
depends on the person sitting I guess.
maybe 3 blocks and a cap. 26"? are the caps 2"? cant remember.
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Old 03-26-2011, 01:47 PM   #4
Cain
Cain
I like Paul's better. mine seemed high
Cain Curtis
A Tile Experience
Old 03-26-2011, 01:52 PM   #5
dhagin
This one was about 20" radius if I remember correctly. I'd cut a chunk of plywood and set it in there on a bucket or something to make sure that it fits their, um, needs.
http://www.johnbridge.com/vbulletin/...ad.php?t=76203
and 'comfort height' or accessible toilets are 18-20" high, chairs about 18".
dana
Old 03-26-2011, 02:48 PM   #6
Lazarus
Lazarus's Avatar
When building a monolithic corner bench, I generally use two cinder blocks plus a 2" solid concrete "cap" piece....and then fill the triangular corners with mason mix and rip-rap. Mud it all to plumb and slant the top a tad.
Laz...
Old 03-26-2011, 02:57 PM   #7
I believe most of mine finish out about 20 inches high. For a corner seat, I try to make the front a minimum of 24 inches across. I make them out of 4x8x16 concrete blocks, two 8 inch blocks tall and another one flat on top of them.
Old 03-26-2011, 03:38 PM   #8
For corner seats I make the front a minimum of 30 in. across. I'm in the school that says a person should actually be able to sit on the seat if they want to.
Old 03-26-2011, 03:52 PM   #9
Trask
Oregon Tile Man
Trask's Avatar
Like John we go a bit larger..on the "square sides" we make them 24"..I forget the measurement on the front edge..but it's the same as a 24x24 tile tip to tip..we often make them larger as folks seem to like a bit more room.
Trask Bergerson
Bergerson Tile and Stone
Astoria, Oregon
Old 03-26-2011, 04:27 PM   #10
figaro
You guys are great! Thanks so much I appreciate it as always. I will be building it out of 2x4's and cbu and then Kerdi.
THANKS!
Figaro
Old 03-26-2011, 04:31 PM   #11
man, you guys got some large customers
I go 17" out from corner and the front is 24" for small bench/seat.
and 20" out from corner and the front is 28" for larger benches
Old 03-26-2011, 04:35 PM   #12
I'll move this over here to the Advice forum, Figaro, on accounta lots of DIYers wanna know the same thing, eh?
I, too, like the 30" across the front on corner benches, and about 17" in finished height.
I generally invite the customer to sit on a dining room chair or other such sitting area and see what's most comfortable for them. Then match that.
The large size Better Bench seems just right when most of my customers have had an opportunity to sit on one.
Old 03-26-2011, 04:53 PM   #13
the better benches are:
17 x 17 x 24
21.5 x 21.5 x 30
underlayment dimensions ob1 Tile Forum/Advice Board 15 04-21-2009 07:02 AM
Modern Dimensions mosaic tile for shower johnapril Tile Forum/Advice Board 8 03-15-2009 05:31 PM
What dimensions for walk-in shower? SteveH Tile Forum/Advice Board 29 01-15-2009 12:38 PM
JakeRockville - Check your seat dimensions JakeRockville Tile Forum/Advice Board 1 01-07-2008 06:47 PM
Curb dimensions dreamer Tile Forum/Advice Board 6 04-24-2002 03:07 PM
