Old 03-23-2011, 01:16 PM   #1
Freida
Enhancing sealer vs regular stone sealer
I have looked and looked for pictures of travertine tile that have been sealed with a clear sealer vs one that has been sealed with an enhancing sealer, and have not been able to find any pics. I like the way my tile looks when it is wet.
Will I achieve this look with a regular stone sealer, or do I need to use an enhancing sealer? One clerk told me that the only difference was that the enhancer made the tile glossy which made the color look richer. If this is true, why do they make regular sealers in matte and glossy and have enhancing sealers,too. I am so confused. Also, my tile man told me to seal the tiles before he lays them to protect them. If I am using an enhancer, do I put it on first?
If I seal with more than one coat, do I continue to seal with the enhancer or then use a regular clear sealer?
Freida
Freida is offline   Reply With Quote
Old 03-23-2011, 01:41 PM   #2
Brian in San Diego
Brian in San Diego's Avatar
Freida,
Enhancer tends to bring out the colors in stone. Each application will make the stone darker and richer in color. An enhancer is also a sealer. Once you have achieved the desired color result with an enhancer then you want to stop applying any more. If additional sealing is necessary then you would want to use an impregnator. I like the StoneTech line of products and use the Enhancer Pro which is a solvent based enhancer. If you want one that's easy to find I would recommend Miracle 511 Enhance and seal. You can find it at Home Repo.
Old 03-23-2011, 02:11 PM   #3
Welcome to the forum, Frieda.
A penetrating sealer is one that soaks INTO the tile and leaves solids in the pores. Once dry, it isn't visible...you can't see a real difference in the tile color.
An enhancing sealer soaks INTO the tile and will bring out the color in a similar fashion to the way wetting the tile does. However, it doesn't leave a glossy coating. This sealer also soaks INTO the tile. If you like the color of the tile when it's wet, this is probably the best option for you. But don't forget that there will not be any real sheen to it once dry.
If you like glossy, then you'll want to use a topical coating. This sealer sits on TOP of the tile and imparts a gloss. I think this is the least desirable sealer because the coating is susceptible to wearing and this degrades the quality of the sheen in a big way. A topical coating requires the most maintenance to keep it up.
So, probably your best option is to take a sample tile an apply any sealer you're considering to it and allow it to dry so you see exactly what the tile will look like. Realize that travertine is a natural material and if you apply an enhancing sealer (vs. the penetrating sealer) the color will vary from tile to tile...in some cases, dramatically.
Typical protocol on sealing natural stone is to seal the face (and the face only of the tile, being careful not to get it on the sides or bottom of the tiles) once before you grout, then a second time after you've grouted. This is for a couple of reasons: 1) the sealer helps prevent the grout from soaking into the face of the tile thereby helping you clean off the grout haze during the grouting process; and 2) the act of grouting can be pretty tough on the sealers and it's a good idea to seal again after the grouting.
...However, using an enhancing sealer (vs. plain penetrating) on natural stone tile can get a little tricky because you have to contend with the grout. Using an enhancing sealer over grout darkens the grout....which might be okay if you choose an artificially lighter color that will darken to your liking, but there's a common problem of the grout taking on the sealer unevenly and becoming rather splotchy. That splotchiness isn't predictable. And the splotchiness is permanent, unless you regrout. If you're okay with both the grout darkening and there being a chance for splotchiness, then do the normal protocol of sealing once before the grouting and a second time after grouting.
But I don't like taking chances, so if I am going to enhance natural stone, I like to do it the day before grouting, then be done with it. I don't want to take that crap shoot on the grout darkening evenly, or very splotchy. So I don't enhance after grouting. If the act of grouting does strip away enough of the enhancing sealer to lighten it's affect, I'll carefully seal the tiles individually with a foam brush, taking great care to not get the sealer on the grout. This also brings up another reason why enhancing natural stone is tricky...if you're going to avoid sealing after grouting, the grout will receive no protective sealer. So it's a good idea to use a grout that has built-in self-sealing qualities or to use a special additive like "Grout Boost" that imparts these sealing qualities.
Old 03-24-2011, 06:09 AM   #4
HS345
Tile Contractor
HS345's Avatar
Excellent posting Bubba.
The name's Greg
Old 03-24-2011, 11:32 AM   #5
StoneTooling
Vending Machine
StoneTooling's Avatar
I took this picture from a sample we put together. Hope it's clear enough.
http://i.imgur.com/INdX0.jpg
Lauren V.
StoneTooling Now shipping internationally!
Visit us and purchase through the sponsored link at the bottom of the page to support the JB forums!
Contractors - send us your information to be listed on our contractor page.
StoneTooling is offline   Reply With Quote
Old 03-25-2011, 04:00 PM   #6
Freida
Smile
Thank you! Thank you, Brian, Bubba, and Daniel, for your input to my questions. Bubba, you were so detailed and concise with your answer. You should write a book "Tiling for Dummies". Based on Brian's answer, I have another question. I definitely think I will be using an enhancing sealer to achieve the effect that I want. Can I use that for the first, protective coat before laying the tile, and then use a penetrating sealer (without enchancer) after installing to better seal the tile. I'm pretty sure the grout I am using already has a sealer in it. I think that is what Brian is saying I can do; but Bubba's answer makes me think if I use an enhancing sealer that additional coats have to be the same sealer. I read the labels on the sealers at Lowes, and the enhancer has moderate protection while their premium sealer has maximum protection. I want to enhance but maximum protection.
Freida
Old 03-28-2011, 12:09 PM   #7
StoneTooling
Vending Machine
We actually wrote a blog post on this last week. You probably have all the answers you need now but here's the link anyways =)
http://stonetooling.wordpress.com/20...ncing-sealers/
You really can't beat the info you get on JB. Some great professionals here.
Lauren V.
Old 03-30-2011, 01:14 PM   #8
Freida
thanks for enhance link
Thank you, Daniel for the link showing a picture of before and after enhancing a tile.
Freida
Old 07-24-2016, 04:39 PM   #9
ksuek
Similarly confused, still don't know what to do
I have two products in my closet. Don't know why, but I do. One is a penetrating sealer, one is a matte color enhancer. Can I use both? Should I use both? Which first. My floor needs maintenence. From what I read, the penetrating sealer should go first, then the color enhancer? I would think the opposite is true. I will throw one out if it is redundant to use both, sticking with the color enhancer only. But the floor is in a bathroom, with kids, so if using both is actually BETTER, I will use both. But WHICH FIRST? Very confused. Thanks experts!
Kris
ksuek is offline   Reply With Quote
Old 07-24-2016, 05:02 PM   #10
Welcome, Kris.
If you'll read the posts above, particularly #2, I think you'll have your answer.
If you would tell the folks specifically what products you have, that may also be helpful. Brand name, make and model. We'd also need to know what you are trying to seal. Photos might be helpful.
You'll also want to note the age of the products. If they have been opened and are older than the manufacturer's recommendation, you may want to dispose of both.
Old 07-24-2016, 07:34 PM   #11
ksuek
Thanks CX.
I don't think #2 applies to me as my floor is not a new installation. But from what I understand, maybe I'm wrong, is you do not use both. You pick one. I can't remember what stone I have, some kind of uneven surfaced 1" tile. Cream, gold, grey, tan streaky/mottled colors. I like the matte enhanced color sealer, so I would opt for that, again, if it unnecessary to use both that and the penetrating sealer. If the protection is sufficient for a bathroom floor. Yeah, both products are kinda old, but thete's no way I can afford more now, so maybe I'll just use the enhancer, and hope to get dome protection until my funds increase. Thanks for all you do to help novices!
Kris
Old 07-24-2016, 07:36 PM   #12
Enhancers are penetrating sealers as a rule, Kris. If you put a penetrating sealer on your stones first, you will not be able to enhance the stone after that.
Old 07-24-2016, 08:43 PM   #13
For years we sealed everything we installed. I can't ever remember using two sealers. If the customer wanted the stone enhanced, that's all we would use. Like CX said, the enhancer is a sealer too.
Enhancing stone sealer turbomangt Cleaning, Restoration and Sealing 3 07-01-2010 01:37 PM
Travertine enhancing sealer cgfletch Tile Forum/Advice Board 2 06-19-2009 05:10 PM
Can Enhancing Sealer be applied over regular sealer? sqerlygirl Cleaning, Restoration and Sealing 1 08-22-2007 04:19 PM
Enhancing Sealer for Travertine h_wood86 Cleaning, Restoration and Sealing 12 02-27-2007 10:03 PM
removing enhancing sealer kkoczan Cleaning, Restoration and Sealing 1 04-24-2006 04:13 AM
