Old 03-12-2011, 05:57 PM   #1
winston43
Best tile cutter?
I have a Felker Tile Master Plus wetsaw and a crappy HD tile cutter. I'm back working part time and will probably average 3-4 jobs a month this year. I want to get a professional grade tile cutter to speed things up and make accurate cuts. I am cutting almost everything on the wetsaw right now. I want to get something that cuts accurately and will last a long time. I'd be happy to get something that cuts up to 13"x13" as most of the bigger stuff is stone anyway. I remember using a piano cutter (?) years ago that I really liked - don't remember the name of it.
Just thought I would ask you fella's who use these tools every day.
Cheers.
winston
winston43 is offline   Reply With Quote
Old 03-12-2011, 06:20 PM   #2
A nice Sigma should last you a long time.Check with Contractors Direct, linked in the earth icon below. They have a nice variety of excellent models.
Old 03-12-2011, 06:27 PM   #3
Chad Deiter Company
Making Cents of It All
Chad Deiter Company's Avatar
Send a message via Yahoo to Chad Deiter Company
I have the 29" Isshi cutter fom Home Depot called the " Brutus" that thing is great and cuts most everything. No cutters can cut everything though I don't think. Some of the waffle backed stuff is always a pain.
Chad from CDC54.com " You Dream It and We Create It "
Southern California Custom Tile and Stone Installation
Chad Deiter Company is offline   Reply With Quote
Old 03-12-2011, 07:01 PM   #4
Toddman
Independent Tile Contractor
Toddman's Avatar
I agree with Chad. I've got a Superior (piano board) that will cut a lot of things up to about a 13" on diagonal I think. And then I have a Rubi, not sure of the model# off hand, and that cuts bigger pieces (up to 24"), but some porcelains just need to be cut on the wet saw from what I've found.
Todd
Good work is not cheap, and cheap work is not good.
http://www.toddthetileguy.com
Toddman is offline   Reply With Quote
Old 03-12-2011, 07:03 PM   #5
winston43
Thanks for the suggestions guys. I should elaborate on that "crappy" HD cutter - it was about $30 - I think so I knew what I was getting! Just building up some $ in the business account so I can finally get a nice one.
Appreciate the advice - I was cutting porcelain on the wetsaw in an almost freezing garage today dreaming of a good cutter.
winston
Old 03-12-2011, 07:05 PM   #6
winston43
Thanks Todd. 13" on diagonal might be a good start for me - the only 18" etc jobs I usually get is Travertine anyway. Do you think one favors the other for accuracy/ease of use or are they pretty similar?
winston
Old 03-12-2011, 08:42 PM   #7
Winston, if you'll enter "tile cutter" into the Advanced Search feature and ask for Titles you'll see forty or fifty threads on the subject.
Old 03-12-2011, 09:12 PM   #8
Mountain Tile
Tile Contractor -- Northeastern PA.
Mountain Tile's Avatar
I have an Ishi and a Sigma, like them both.
Mountain Tile is offline   Reply With Quote
Old 03-12-2011, 10:16 PM   #9
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
I have a Rubi and a Sigma and like them both. Anything is better than a $30 cutter. Get something that cuts at least 18" tile. As soon as you buy one for 13" you will get a 18" porcelain job
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Old 03-12-2011, 10:21 PM   #10
Kilauea
LT
Kilauea's Avatar
Thank you,CX!! There's about a million threads already on this subj!!
*L.T.*
tandctile-dot-net
2nd generation tile installer
The apprentice rocket scientist was having a hard time programming the launching sequence.His professor watched impaitently and said,"C'mon its not tilesetting!!!"
Kilauea is offline   Reply With Quote
Old 03-12-2011, 11:21 PM   #11
duneslider
Utah Tile Contractor
Seems like I have been using my cutter less and less lately. Seems so many of the tiles now just won't cut well on the cutter. Even with a brand new cutting wheel I am having issues.
Did a little bathroom tonight and it was a really nice tile, fairly expensive American made, and it would not cut on the cutter.
Bryan
EX Tile Contractor
Positive Tile and Stone
Salt Lake City, Utah
duneslider is offline   Reply With Quote
Old 03-13-2011, 05:28 AM   #12
Levi the Tile Guy
Levi the Tile Guy's Avatar
Amen, Brother. I have a Rubi and a Sigma. I liked the Rubi, till I got the Sigma. When I first got the Sigma though I thought it was junk, then I figured it out. Lately I have been working with real hard porcelain on almost every job. I end up using the saw most of the time, it is just to hard to break clean and consistently with a cutter.
Levi The Tile Guy
Old 03-13-2011, 05:54 AM   #13
giarc25
giarc25's Avatar
I have the Felker FPC-19 and love it! The bad thing about it though is you can't find them anymore. It is pretty much the same thing as the Ishi from what I've seen and read though. You won't regret getting the Ishi, nice clean cuts, and time tested accuracy (at least from my personal experience).
Craig
giarc25 is offline   Reply With Quote
Old 03-13-2011, 06:57 AM   #14
pgc555
So the antie is $.02 - Many have already expressed this. The tile we are using today is more Porcelain ( the HARDEST tile you can get ) or stone ( of some sort ) Wet saw cuts for everything. I haven't got a large format CERAMIC job in a long time. Invest your money in a good wet saw that will do large ( 20x20 or 24x24 )
on a 45 and you'll be fine for a long time in this trade. Speed is not as much of a priority over quality of install. Charge a little more and take your time to do a job that you are proud of and will last.
Phil,
http://www.edgestripkits.com/
pgc555 is offline   Reply With Quote
Old 03-13-2011, 07:42 AM   #15
Raymondo
Raymondo's Avatar
I've got a Tomecanic and haven't run into a porcelain yet that it couldn't cut.
Casey
www.barefoot-tile.com
Raymondo is offline   Reply With Quote
tile cutter gramps Tile Forum/Advice Board 4 07-22-2010 10:05 AM
Tile Cutter 420benz Tile Forum/Advice Board 5 03-27-2010 06:56 PM
looking for best tile cutter RexModeling Professionals' Hangout 16 12-04-2005 08:20 AM
will a tile cutter help? 30all Tile Forum/Advice Board 5 07-21-2004 01:36 PM
Tile Cutter Rex Tile Forum/Advice Board 23 11-08-2002 02:56 PM
