Old 02-15-2011, 10:44 PM   #1
JMcCorison
JMcCorison's Avatar
When to Change a Wet Saw Blade
I have been loaned an MK-101 wet saw while a contractor friend is off vacationing for 6 weeks. It is obvious that maintenance has not been one of the important line items on the task list. After cutting a few 12" tiles I found that the saw is out of true by 1/8" over 12". So I'll spend some time cleaning it up and truing it. I believe in returning tools in better condition than I borrowed them, so I don't mind. Besides, I want my job to look good even if he doesn't care about his.
How does one know if the blade needs to be dressed or replaced. MK's manual says that a wandering cut indicates the blade needs to be dressed. Fair enough. But what are the signs that the blade needs replacement?
Jim
Marine Electrician by day Starfish Marine
House Builder by night
JMcCorison is offline   Reply With Quote
Old 02-15-2011, 10:51 PM   #2
Does the blade cut off by 1/8"? = drift?
OR
Does the cart travel crooked by 1/8" when its slid back and forth? = a different problem.
If its A, then dressing the blade or a different blade will be in order. Some porcelains are so hard, they require excellent blades.
OR
Do yourself a favor, and buy your own Raimondi Razor Gold or Razor T-3.
Old 02-16-2011, 12:35 PM   #3
JMcCorison
JMcCorison's Avatar
Thanks Paul. I checked the run out on the saw and it is out, but only by 1/32", if that. So new blade time. In theory UPS should be dropping a new Raimondi Razor T-3 on my doorstep on Friday. I guess I'll consider it rent on the saw.
Jim
Old 02-16-2011, 12:37 PM   #4
Hi Jim, you never said what you're cutting. Is it porcelain?
Old 02-16-2011, 01:20 PM   #5
Cain
Cain
that blade is so good you are going to want to buy your own saw to put it on!
if your buddy is using a beat up saw, with a beat up blade, he may not even appreciate the gift you just got him.
can you tell I like that blade?
Cain Curtis
A Tile Experience
Certified Tile Installer #362
Cain is offline   Reply With Quote
Old 02-16-2011, 06:02 PM   #6
JMcCorison
JMcCorison's Avatar
Tonto, I'm cutting some porcelain tiles from Fondovalle. I've also got a bunch of cutting to do on some Florida Tile porcelain as well. I'll be turning a bunch of 13" tiles into 3-1/2" tiles. So getting a good blade will certainly be worth it.
Cain, Actually, the saw isn't too beat up. The belt squeaks when you first turn it on, it really needs the dust cleaned out of it, and a minor truing. So I'll do it up for him. I don't have enough need to justify purchasing my own saw. And as much as I like tiling, I'm getting way to busy with my marine business to take on something else.
Jim
Old 02-17-2011, 12:23 AM   #7
That blade will serve you well. I know what it's like turning big tiles into lots of small tiles. Enough to drive you from all the cutting.
Old 02-21-2011, 10:16 AM   #8
JMcCorison
JMcCorison's Avatar
Smile Wow!
I put the new T-3 blade on and what a difference! The fireplace surround tiles are 13-1/2" porcelain. I was able to shave off a perfectly intact strip less than 1/8" wide. In addition to cutting dead straight, it is also a lot faster and easier to cut than before. Call me a happy camper.
Jim
Old 02-21-2011, 11:57 AM   #9
Sorry, that name's been taken.
Old 02-21-2011, 12:00 PM   #10
Jim,
I'm glad you made the right choice. T3 Razors are the bomb.
Blade change theosmom Tile Forum/Advice Board 1 06-20-2010 04:33 PM
Can't change blade on MK Raymondo Professionals' Hangout 8 08-04-2007 05:58 PM
Wet Saw Blade Ed-diy Professionals' Hangout 5 07-22-2006 10:55 PM
MK-470 blade change DaveCT Tile Forum/Advice Board 0 07-05-2006 07:04 AM
Change blade on mk101 robertser Tile Forum/Advice Board 5 07-06-2005 11:39 PM
