Old 02-15-2011, 03:24 PM   #1
lowerb
tiling adjoining room
In 1986 I tiled my house (everything except the bedrooms and living room) in the largest tile available at that time (8X8). Due to my small living room looking a bit chopped (adjoining the kitchen and hallway) an interior decorator suggested that it would look much better if I would pull out the existing carpet and use ceremic tile to make the rooms flow a bit better and take in more space for the living room (the carpet makes it feels as if the room ends with the line of the carpet) As you can imagine, the Natura 8303 tile put down 25 years ago is long since discontinued. Is it better to attempt to "match" the tile or can you use a 12X12 or even larger. I'm just not sure what to do to make the room flow even though I cannot use the same tile. I just don't want to use a larger tile and have it look like a big afterthought. Is there a way to make different tiles in adjoining rooms look good? I don't think that using something completely different (like wood) would work because the point is to make the room flow better and to make it feel like one common area instead of 2 or 3 smaller ones. HELP!!
Beverly
lowerb is offline   Reply With Quote
Old 02-15-2011, 03:49 PM   #2
Welcome, Beverly.
Wood might be an attractive compliment. Really depends on what the area looks like. Do you have a pic of the area to help us make suggestions? That might spark an idea to suggest putting the new tile on a 45 degree angle, using a picture frame around the area, etc.
Old 02-15-2011, 04:28 PM   #3
muskymike
muskymike's Avatar
Hi Beverly, welcome! You could use the same size tile or bigger in a similar color making a 3" piece to use as a border to break up the areas so it doesn't look like an after thought. It will look like you meant it to be that way.
Musky Mike
Corrado Custom Tile
Kerdi Shower Specialist
New here? Check this out.
tile adjoining hardwood floor and carpet Mark V Tile Forum/Advice Board 5 10-23-2008 08:06 AM
linoleum tile in corner with adjoining molding. mjreisbord Tile Forum/Advice Board 3 06-18-2006 10:42 PM
Tiling two adjoining rooms - Layout help KurtisPA Tile Forum/Advice Board 1 05-03-2006 08:48 PM
Adjoining room floor height issue Bea Tyler Tile Forum/Advice Board 12 04-10-2004 05:40 AM
Tiling over basement and adjoining crawl space Jef Hoeberichts Tile Forum/Advice Board 6 03-09-2004 03:53 PM
