Old 11-17-2010, 07:47 PM   #16
Davestone
Florida Tile & Stone Man
I did a job one time with Mapei grout.It was summer and after it dried it turned yellow.So yellow in fact i thought it was pollen which we get a lot of sometimes.I tried to wipe it off and it wouldn't come off.I freaked and got out the vinegar and a brush and it took it right off.It never happened since and i have no idea why or what it was.
http://Davestonestile.com
Old 11-18-2010, 12:13 AM   #17
Jim Farrell Tiler
Jim Farrell Tiler's Avatar
i had a grout supplier tell me today ALL epoxy grour goes yello if in sunlight
Jim
no matter where you go.......there you are
Jim Farrell Tiler is online now   Reply With Quote
Old 11-18-2010, 10:32 AM   #18
Pirate
It does make sense that it would yellow, that's what epoxy does. If it was a darker color, the yellowing would just darken it more, which probably wouldn't be objectionable.
Randy
Pirate is offline   Reply With Quote
Old 11-18-2010, 10:48 AM   #19
cheford280
Hopefully I am not hijacking the thread
I am a little scared now. I am working on a bathroom which has a skylight.
I have not grouted yet, but already purchased spectralock bright white!
Should I be concerned (it is too late for that I guess)?
Jesse
cheford280 is offline   Reply With Quote
Old 11-18-2010, 05:35 PM   #20
Apollo
Apollo's Avatar
If it were true that all epoxy yellows, then I think the whole shower would yellow. If you take a close look a the first picture you can see that it goes from "Bright White" at the top where the water doesn't hit it, to "yellow" where the water hits it a little lower. My aunt is the home owner, so she offered to do the soft scrub with bleach (thank god, I don't want to get Popeye arm this week). I will let you know if it works or not. If not it looks like I might have to Picasso it with the grout colorant.
Shane
Apollo is offline   Reply With Quote
Old 11-18-2010, 06:27 PM   #21
tileman2000
New England Tile Man
tileman2000's Avatar
I had a white grout turn yellow in a shower and outside walls.Never found a reason and bleach,which did turn it white again..didn't last.I ended up using silver Aquamix grout colorant and 3 years later the joints still looks the same.
Michael
Old 12-06-2010, 11:06 AM   #22
CWMCPA
Any updates to this thread? I'm about to use Custom's white epoxy grout in my bathroom.
Warren
CWMCPA is offline   Reply With Quote
Old 12-06-2010, 11:26 AM   #23
Warren,
I don't know if CB epoxy has been around long enough for the pro's to voice an opinion.
Old 12-06-2010, 12:10 PM   #24
CWMCPA
Paul,
Thanks. Any comments on other brands? Is epoxy yellowing a thing of the past?
Warren
Old 07-31-2012, 11:05 PM   #25
dwilderness
Same experience
I had my bathroom remodeled several months ago, and the licensed contractor used SpectraLock in bright white. I have experienced the exact same problem mentioned here. Additionally, the grout stains easily. No cleaning product or method I've used seems to work, both on the yellowing and the stains. I am not sure what to do. I cannot call the contractor. After they blotched the quartz countertop, it was clear that they were not going to take responsibility for any thing else that went wrong.
J. Lee
dwilderness is offline   Reply With Quote
Old 07-31-2012, 11:21 PM   #26
jwmezzanotte
jwmezzanotte's Avatar
Wow, old thread.
I had the same problem with some white Mapei Kerapoxy I installed a few years ago. The customer wasn't upset about it, so it was a non issue.
If it had become an issue, I really dont know what I would have done about it
Did some more white epoxy a couple years later and fore-warned the customer about the issue I had. Did the job... no issues. Again
Old 10-29-2012, 07:55 PM   #27
disalex
I have exactly the same issue with specra lock Ultra white, I have tried everything including acid cleaners etc, nothing seems to help
Alex
disalex is offline   Reply With Quote
Old 03-05-2013, 03:03 PM   #28
jim_c
doitmyselfer
Just a thought which may be very obvious:
Could it be that the water has iron in it and the yellowing is actually rust?
Are there any other areas in the house with discoloured fixtures, like toilets or sinks?
Can you get a sample of the water from the house and have it tested at a lab for iron content?
We used to see this in old houses when I was a kid and the pipes and fixtures were all made with cheap steel.
Jim
jim_c is offline   Reply With Quote
Old 03-05-2013, 03:04 PM   #29
jim_c
doitmyselfer
Does this mean I should change my mind and not use Spectralock in the shower I am about to tile?
Jim
Jim
Old 03-05-2013, 05:08 PM   #30
Stone Dude
Try cleaning with diluted bleach or hydrogen peroxide and warm water.
Cameron DeMille
SFA, MIA
MillestoneMarble.com
Dark grout turning white, ceramic shower tiley Tile Forum/Advice Board 9 02-27-2013 12:20 PM
tile turning white hawiianlw Cleaning, Restoration and Sealing 2 07-29-2010 09:54 AM
Ultra white grout turning brownish? Larryl9797 Tile Forum/Advice Board 2 05-26-2009 09:52 AM
Dark grout turning WHITE!!?!?? esc Tile Forum/Advice Board 5 12-24-2008 10:53 AM
Grout turning out white, need help BroNeilson Professionals' Hangout 16 11-17-2005 01:20 PM
