Old 11-06-2010, 09:48 PM   #1
zootjeff
Vinegar as a daily shower cleaner?
Hi,
We have a porcelain tile shower with epoxy grout and Delta Stainless shower fixtures (Lockwood series). We were wondering if there is an issue spraying it down with vinegar/water solution after use daily. Can vinegar damage the fixtures or the grout? Is there a better way to do it?
The epoxy grout says not to use enzymatic cleaners, what does that mean anyway?
-Jeff
Jeff
zootjeff is offline   Reply With Quote
Old 11-07-2010, 05:45 AM   #2
Davestone
Florida Tile & Stone Man
I wouldn't do that,typically a neutral cleaner is all that's needed on a daily basis.The vinegar with it's high acid base will start to ruin everything,fixtures,ceramic finishes,drains and such.Once in awhile if needed use the acidic cleaners to get the soap scum and minerals off.
Enzyme cleaners are some of the citrus based cleaners.
http://Davestonestile.com
Old 11-07-2010, 12:09 PM   #3
zootjeff
Do you know anything about method brand daily shower? What are some examples of a neutral shower cleaner?
-Jeff
Jeff
Old 11-07-2010, 12:22 PM   #4
Davestone
I don't know anythng about that.Here's a link to various types,i know here Lowes has a neutral cleaner in it's cleaning section,i think it's called Redmax...http://www.google.com/search?q=neutr...rlz=1I7GGLA_en
Old 11-07-2010, 01:42 PM   #5
Plus the odor ... your bath would smell like a pickle jar...
Old 11-07-2010, 06:38 PM   #6
Tiletim
Lost in the details
Tiletim's Avatar
Jeff, here is a good one.
dupont/Stonetech Cleaner
Tim
Tiletim is offline   Reply With Quote
Old 11-07-2010, 07:39 PM   #7
Crestone Tile
Gonzo!
Porcelain with epoxy ... the best cleaner is a squeegee. Seriously.
Matt
"Shut it down!"
Crestone Tile is offline   Reply With Quote
Old 11-08-2010, 12:20 PM   #8
StoneTooling
Vending Machine
StoneTooling's Avatar
Here is the Stone and Tile cleaner at a better price:
http://www.stonetechdirect.com/servl...Tile%2C/Detail
We are also giving 5% off any order to JB members right now. PM me if you're interested.
As far as stainless fixtures go, they are stainless, I wouldn't clean it with anything but water and a rag.
Lauren V.
StoneTooling Now shipping internationally!
Visit us and purchase through the sponsored link at the bottom of the page to support the JB forums!
Contractors - send us your information to be listed on our contractor page.
StoneTooling is offline   Reply With Quote
Old 11-10-2010, 05:44 PM   #9
SABoyt
Tile, stone and grout cleaning and restoration
SABoyt's Avatar
I agree with Matt. You don't want to use too many chemicals on the epoxy. It will yellow over time anyway, but using a lot of cleaning chems can dramatically speed that yellowing process.
Steve
www.HSSflorida.com
Cleaning and Restoration Services - HSMPA Certified Master Cleaner and Instructor
TMTrecovery.com
New and used Truck mounts
Cleaning and Sealing Trainer
ColorCladô Premium ColorSeal Distributor
SABoyt is offline   Reply With Quote
Old 11-11-2010, 09:10 PM   #10
cstlouis7
cstlouis7
Vinegar is fine
Laticrete epoxy recommends that you use vinegar to clean it, i called them on it when i first used epoxy grout and had a nice haze that would not come off. The vinegar was not strong enough to remove the thin layer of epoxy but it will be fine for everyday cleaning. I ended up having to use sulfamic acid and silicia sand together and scrub with a home made drill scrub brush machine. It is not a dumb question, call the manufacturer of your grout i bet a $1.28 that they have been asked it so many times anybody who answers will know the answer.
cstlouis7 is offline   Reply With Quote
Old 11-21-2010, 08:36 PM   #11
Toddman
Independent Tile Contractor
Toddman's Avatar
Like Crestone Tile said, the best maintenance is to squeegee the water off the walls after EVERY shower. It doesn't have to be completely dry, but just get in the habit and take ONE minute to get the majority of the water off. Then, take a towel and dry off your stainless fixture. Very simple!
IMO vinegar is not a good idea.
Todd
Good work is not cheap, and cheap work is not good.
http://www.toddthetileguy.com
Toddman is offline   Reply With Quote
Old 12-14-2010, 07:34 PM   #12
ob1kanobee
ob1kanobee's Avatar
I use a daily body scrub that is lavender scented and once a week for sure whether I need it or not.
Ben
Marble in a Daily Shower bkfire27 Tile Forum/Advice Board 2 03-05-2009 11:13 PM
Hunting Season - The Daily Bag tileguytodd The Mud Box 19 10-14-2006 02:37 PM
daily shower cleaner slider Cleaning, Restoration and Sealing 1 07-15-2006 07:06 PM
daily buzz scott anthony The Mud Box 1 03-12-2006 08:05 AM
Daily Countertop cleaner Billywj Cleaning, Restoration and Sealing 2 10-20-2005 09:35 PM
