Old 10-07-2010, 04:44 PM   #1
DeAnn
How do I seal and shine tile floors?
We have just layed ceramic floors in a new construction and I would like to know what do I need to do get them ready for everyday use and get a better shine. They are matte finish and not a bit of shine. I'm looking at a high gloss or semi gloss sealer after I seal the grout. Can anyone give this 51 year old blonde some simple steps of what to do after the installer has completed the installation?
DeAnn
DeAnn is offline   Reply With Quote
Old 10-07-2010, 05:39 PM   #2
If its a ceramic tile I don't know if you can change its appearance. The grout can be sealed with Enrich N' Seal by aquamix if you want to darken it and give it a glossy look.
Old 10-08-2010, 12:43 AM   #3
kate16
What are the procedures that are carried out while sealing the marble tile...?
kate16 is offline   Reply With Quote
Old 10-08-2010, 02:48 AM   #4
Davestone
Florida Tile & Stone Man
Any high gloss sealer applied of course will wear and have to be reapplied so we generally don't advise it.The best solution of course is to clean it thoroughly after grouting,or pick a tile with a shiny finish,
Generall for sealing you clean the tile,let dry then apply sealer with an applicator and wipe off excess before it dries,don't apply it to the tile,just the joint.
http://Davestonestile.com
Old 10-08-2010, 02:56 PM   #5
SABoyt
Tile, stone and grout cleaning and restoration
SABoyt's Avatar
DO NOT put a sealer on top of glazed ceramic. This will be a disaster for you. Glazed ceramic is non-pourous. It's absorbency rate is almost 0. Sealer are make to be impregnated into the pourous parts of the tile or grout. Since there is no porous part, and as i may have already mentioned, DO NOT put a sealer on glazed ceramic tile.
If you bought the wrong tile and have decided you want it to have a sheen, then use a topical - but this is not without heavy maintenance requirements itself.
Steve
www.HSSflorida.com
Cleaning and Restoration Services - HSMPA Certified Master Cleaner and Instructor
TMTrecovery.com
New and used Truck mounts
Cleaning and Sealing Trainer
ColorClad™ Premium ColorSeal Distributor
SABoyt is offline   Reply With Quote
Old 10-08-2010, 03:23 PM   #6
Welcome also, Shelly Smith.
Please start a new thread for your project with a lot more information so's not to confuse this one and not to lose information on yours.
Old 10-09-2010, 01:53 AM   #7
kate16
Thanks for replying....I'll see to that...
Getting shine back in tile rambo1224 Cleaning, Restoration and Sealing 2 08-13-2009 07:37 PM
can I seal tile that has no shine? Bob Ferry Cleaning, Restoration and Sealing 2 07-31-2008 10:54 AM
Restoring shine to old tile dunazee Cleaning, Restoration and Sealing 2 11-25-2007 09:54 PM
Travertine seal,shine questions wcs Cleaning, Restoration and Sealing 6 11-28-2006 03:32 AM
Ready to seal but want some shine browen Cleaning, Restoration and Sealing 4 03-30-2004 06:17 PM
