Old 09-30-2010, 09:47 AM   #1
mxrruss
Which grout for 1/16" AND 3/16" grout lines
I am doing a backsplash with 3/16" grout lines around 3x6 travertine. I would like to cut some strips of smaller glass tiles from a 12"x12" mat to insert as a boarder. The problem is the tiles on the mat have 1/16" grout lines. I know I must use sanded grout for the 3/16" but will sanded be OK on the 1/16" spaces as well?
Russ
Russ
mxrruss is offline   Reply With Quote
Old 09-30-2010, 09:53 AM   #2
You've got to be a bit cautious when using sanded grout with glass due to the possibility of scratching. Some glass scratches and some don't. Test grouting over a sample glass tile before you commit fully so you aren't surprised on your installed tiles. On that point, Laticrete's Permacolor would probably fit your needs very well because the sand used in the formula is smaller and more rounded in shape than typical sanded grouts...so it's less likely to scratch. And unlike other sanded grouts, it has a range from 1/16" to 1/2" width grout lines.
When I need to use a cementitious grout, Permacolor is my first choice...especially because the final dried grout matches the sample colors...no surprises on color variations. Take a look at Laticrete's "Toasted Almond" color...might be a good color for you?
Old 09-30-2010, 10:47 AM   #3
Scottish Tile and Stone
Def. use permacolor.. That grout is perfect for your application
Scott.
www.scottishtileandstone.com
Laticrete hydroban showers
Mud set stone.
Old 09-30-2010, 11:40 AM   #4
Add one more vote for permacolor. It shouldn't scratch and will also work in those smaller joints quite well.
Mix smaller batches as you get the hang of it
Old 09-30-2010, 05:52 PM   #5
Lazarus
Lazarus's Avatar
Like Paul said....Permacolor is the way to go.
Laz...
Old 10-01-2010, 09:52 AM   #6
mxrruss
Thanks for the replies. I just assumed all sanded grout was for grout lines 1/8" or more. Good to know Permacolor will work in 1/16".
Russ
Travertine Shower, 1/8" Grout Lines. Best Grout? funk Tile Forum/Advice Board 16 06-17-2009 09:20 PM
spectralock mini epoxy grout - 1/16" grout lines zoomzoom3 Tile Forum/Advice Board 7 11-05-2008 11:36 AM
Is sanded grout 1/16" in grout lines really a bad thing? pja5362 Tile Forum/Advice Board 3 08-30-2008 10:07 AM
1/4" grout lines or very thin 1/8" Crazymo Tile Forum/Advice Board 5 03-25-2007 02:31 PM
Recommendation for epoxy grout for 1/16" grout lines Pauster Tile Forum/Advice Board 5 07-06-2005 07:52 AM
