Old 08-24-2010, 03:45 PM   #1
cb9209
Tiling wall at Tub Apron
Ok, I'm new to the forum and certainly new to tiling so I have what I hope to be a simple question.
I am redoing my main bathroom and have installed the tub and hardibacker on the walls within the tub/shower area. However, the bathroom is very small and the tub is 1/2" shy of an outside corner. All that is visible is the end of a piece of drywall that is on the wall that the apron is in line with.. I do not see any chance of tiling this so how do I finish the edge? Will a pvc piece of trim/moulding suffice providing it is caulked/silicone properly?
Open to suggestions.
Thanks in advance
Chad
cb9209 is offline   Reply With Quote
Old 08-24-2010, 04:02 PM   #2
Davestone
Florida Tile & Stone Man
You could do that Chad,i have trimmed pieces of bullnose on a wetsaw pretty tiny but it ain't easy.
http://Davestonestile.com
Old 08-24-2010, 04:22 PM   #3
matman
Tile contractor
Hi Chad one option that will help make that skinny cut a bit wider is to run your cap pieces beyond the end of the tub wall by the thickness of a tile. You then turn the corner and run the cap pieces on the bath wall with the finished edge away from the tub wall edge, finishing the install on the bath wall.
If you're tiling to the ceiling you'll have a straight row of cap, ceiling to floor on the bath wall. If you're only tiling 5 ft. above the tub you're gonna need an outside corner at the 5 ft level
Doing that will enlarge the skinny to about 3/4 of an in. , strong with a little extra mud on the wall caps. Walls have to be fairly plumb for it to look good and I don't know if you can do that without seeing it.
Matt
matman is offline   Reply With Quote
Old 08-25-2010, 03:44 AM   #4
cb9209
Method of Tiling Wall and Waterproofing?
Two questions.
1. I have hardibacker as my wall base. Do I need to apply red gaurd, especially if one wall is an exterior wall? I backer is installed over faced insulation. The other two walls are non insulated interior walls.
2. When tiling on the vertical, what is the best method to the madness? Do I start low, high or in the middle? I've seen one method by tacking up a 2x4 ledger to support the first row and up. Then once that cures you finish off the bottom section. Do I tape each row in place in lieu of that?
Chad
Old 08-25-2010, 04:25 AM   #5
Scottish Tile and Stone
Chad, is this a full shower or tub surround.?
You will need spacers for the walls.. I like to either start off the floor or use a ledger board 1 row up and start there. Alot depends on tile size and the layout
Scott.
www.scottishtileandstone.com
Laticrete hydroban showers
Mud set stone.
Old 08-25-2010, 04:49 AM   #6
cb9209
It's a tub/shower. I plan on using 6" tiles.
I also have another question. What is the best product for waterproofing grout? After dealing with a mold issue I don't want to take any chances. Do I use laticrete grout? An epoxy grout sealer? Heck, I don't even know the differences especially after reading so many different things. So far this has seem to be the most knowledge filled website.
I was planning on tiling starting saturday so if I had to redgaurd the walls I guess I would have to do that Friday? Is that enough cure time? To be honest, I'm leary on redgaurd. I've read stories of it peeling right now (ie, not bonding with hardibacker). I am soooo paranoid now about getting water behind the tile.
Chad
Old 08-25-2010, 05:00 AM   #7
Chad, you need only one layer of waterproofing, and only one vapor barrier. (I'm going to intentially mis-use these terms, but it's for a good purpose, so bear with me.) Your insulation has a vapor barrier in the kraft paper facing. That will stop water vapor that penetrates your walls from contacting a colder surface near the exterior of the house and condensing. This vapor will gladly move back into your house when the conditions are right. Adding a moisture barrier to the inside face of your backerboard will not entirely prevent water vapor from reaching the vapor barrier, but may restrict the vapor from returning to the interior. So, the vapor gets trapped inside the walls. Bad thing, that.
What to do? Have only one vapor retarder in the system. (Kraft paper is really a vapor retarder, as is Redgard, and any other membrane that has a Perm rating higher than 1.) Because you still need a moisture barrier, and kraft paper can't be it, you need to defeat the kraft paper with a series of slits to allow vapor to pass through easily. The, install the backerboard and coat it with 2 coats of Redgard. This meets all the requirements of having one moisture barrier and one vapor retarder in your wall system.
For further reading, do a site search for "Moisture Sandwich." Bring a lunch.
Old 08-25-2010, 05:04 AM   #8
You really cant waterproof grout.
Seeing this is a tub, I would start my first row right off the tub MAKING sure the tub is level all the way around..
Scott.
Mud set stone.
Old 08-25-2010, 05:05 AM   #9
If you want a waterproof grout, an epoxy grout is the way to go. Laticrete's Spectralok is a good, easy to use version that Lowes carries. Check your quantities and verify they have enough of your color in the same dye lot in stock. If not, have them order it for you, but demand the same dye lot.
Epoxy grout never needs sealing. Good, eh?
Best way to deal with mold is to deny the little buggers a source of water. Use a vent fan with a timer to run for 20 minutes after the shower. Make the fan large enough to exchange the air in the bathroom at least 8 times per hour. Dry the shower with a squeegee or towel after the last shower of the day. Dry bathrooms do not mold.
Old 08-25-2010, 05:06 AM   #10
I personally am not a fan of Redguard. If you have a lowes close, see if they carry Laticrete and get a small tub of water tight.. Its about $50.
Scott.
Mud set stone.
Old 08-25-2010, 05:09 AM   #11
Didnt think spectralock was waterproof? Stainproof yes
Scott.
Mud set stone.
Old 08-25-2010, 05:20 AM   #12
cb9209
I've actually already cut the slits in the kraft facing of the insulation so I'm good there. It's really just how I handle the tiling side of the hardibacker. I've extended the hardi down slightly past the tiling flange of the tub so that water will not land behind the tub between the walls.
I guess like you say, if water can't get past the hardi/moisture barrier then I wouldn't need waterproof grout. I think if I went with the laticrete water proofing and also epoxy grout I could rest easy.
Is epoxy grout tough to deal with? I've done one other tile job and used a pre-mixed sand type grout which was EASY to use and more importantly, to clean. Having used an epoxy product before on repairing plastic, it's not very friendly to me.
Chad
Old 08-25-2010, 05:26 AM   #13
Scotty, you are correct, Spectralok is not a substitute for a moisture barrier. I did not mean to imply that it was. Sorry for any confusion.
I found Spectralok fairly easy to work with. You do have to pay attention to the cleaning instructions, but they are not that hard. Like all grouts, you do not want to get too far ahead of yourself. I used mini-units and found that they were the right size for me to spread and clean up.
Old 08-25-2010, 05:52 AM   #14
cb9209
forgive my ignorance but what is a mini-unit? I'm assuming the amount of grout.
Chad
Old 08-25-2010, 06:00 AM   #15
mini units are smaller packs of spectralock.. Those are the ones sold at lowes. The pro units are bigger ones used for bigger jobs
Scott.
Mud set stone.
Tiling Countertop Method shuddleston Tile Forum/Advice Board 10 08-25-2006 06:53 PM
Method for tiling over exterior deck crislee Tile Forum/Advice Board 4 09-30-2005 11:54 AM
Help me understand the wall first method for showers beat Tile Forum/Advice Board 3 10-27-2004 07:46 PM
Wall tiling method bigjed Tile Forum/Advice Board 19 03-18-2004 08:22 AM
Inside Corner Grout Method for Wall Tile bheinack Tile Forum/Advice Board 4 01-28-2003 06:13 PM
