Old 08-24-2010, 10:42 AM   #1
walleye guy
HELP! Mixing grout and caulk???
So I see the current issue of this magazine "Family Handyman" and they have a little article about caulk/grout. In a nutshell, it says you should caulk where planes meet as is the prevailing wisdom, but goes on to say that when you can't find caulking to match your grout... you can blend your grout with regular caulking and pipe it in to the corners using a zip-top bag.
This one doesn't pass the sniff test for me, but can anyone attest to trying this?
I'm asking mostly out of curiosity, since it's like nothing I've ever heard. BUT ALSO, I have a problem of my own that needs fixing. After finishing my shower (mud bed with marble mosaics meeting 12x12 ceramics on the walls, over Hardi), I've apparently miscalculated my height when I used the ledger for the first row, and I'm left with about a 1/2" gap between the wall and floor tiles at one end of the shower. In addition, I ended the floor tiles close to a 1/2" from the wall boards at that same end of the shower. When you add the thickness of each tile, about 3/8", I'm left with a bit of a cavernous gap. Not sure what the best bet would be to fill this void.. sanded grout, generous bead of caulking, something else? While the grout/caulk blend sounds suspect it has me thinking ... hey, split the difference!
Greg
Last edited by walleye guy; 08-25-2010 at 09:46 AM. Reason: fixing typos for clarity
walleye guy is offline   Reply With Quote
Old 08-24-2010, 12:44 PM   #2
Winter River
DIYer with more projects than time
The experts will be along soon. In the meantime, post some pichers of the gaps. It'll be the first thing they ask for.
Elise
Winter River is offline   Reply With Quote
Old 08-24-2010, 09:59 PM   #3
About mixing grout with 100% silicone caulk: it can be done, but realize it will reduce the flexible properties of the silicone based on how much powder you mix in. Between Laticrete, Tec, and ColorRite, there's a LOT of 100% silicone colors available to you and mixing can be avoided.
About that 1/2" gap between the first course of wall tiles and the floor tile: I'd cut a strip of tile in there to reduce it to 1/8" or a bit less. It'll be less noticeable than a big honkin' caulk joint.
The second gap you speak of: not sure how big that gap is. Don't quite understand and a picture would be real helpful.
Old 08-24-2010, 10:21 PM   #4
Greg, there is a fella not all that far from moi, here in the south of Texas, America, who has started a business doing exactly what you suggest. I can't think of his name right off hand, but I'll see can't I find his website for you.
He's sent queries about advertising here, and I've asked for some samples of the product, but never gotten a response. I'd like to give it a try. Sounds like a good eye-dee to moi.
[Edit]
Here's the fella's website: http://www.earthmasterproducts.com/Home_Page.html
Fella name of Scott Higbie is the creator, I believe. If you talk with him, tell him we can't help him if he won't answer his emails, eh?
Old 08-25-2010, 09:53 AM   #5
walleye guy
thanks for the replies gents... attached is a sketch that shows the issue with the gap, basically the wall tile is about a 1/2" shy of the mud bed, and the floor tiles are about 1/2" shy of the CBU wall boards, so there isn't a really big gap between the tiles, but a big air space behind there.
If I'm OK with the look of a caulked joint that big, the question is, is a bead that big even going to set up, or am I asking for problems?
Working on getting the Mrs. to get me some photos to post.
Greg
Old 08-25-2010, 10:54 AM   #6
I'd do as Bubba said. Cut a sliver and slip it under the wall tile.
Old 08-25-2010, 10:59 AM   #7
What Bubba said.
If your tile saw does the 'plunge feature" you can use that to make a super thin sliver if you need to go that skinny.
Yes, they are a nightmare to install after the fact. Thinset will ooze up and make a mess. Let that set for a spell, then before it fully cures, go back and dig out the excess thinset without disturbing the sliver.
Old 08-25-2010, 12:00 PM   #8
walleye guy
Thanks for the suggestions, sounds like I'm going to have to set some more tile.
Not sure if this changes anything, but here are a couple photos; basically at the widest point there is about 5/8"-3/4" gap between the wall tile and the top of the floor tiles (1x1s), then maybe a 1/4" - 3/8" gap between the mosaics and the wall, which is mostly covered by the depth of the wall tiles. As you can see I already have made a mess with grout and thinset in there, so going with some slivers is going to need some chiseling or something.
Greg
Old 08-25-2010, 04:06 PM   #9
Greg,
yep, a fine little mess you've made. Nothing that can't be fixed. Get yerself some good knee pads, a grout removal tool or Fein tool, an d have at it to carefully scrape out the offending grout and thinset. Have some scrap tile handy to check for depth so you don't take out too little. Be careful not to puncture your waterproofing.
Its annoying, PITA work. No real way to make it easier. Sorry buddy.
grout mixing scott anthony Professionals' Hangout 31 12-08-2009 11:03 PM
Mixing Grout liebermg Tile Forum/Advice Board 2 09-15-2008 09:52 AM
mixing grout handy_guy Tile Forum/Advice Board 1 05-02-2008 02:40 AM
Mixing grout ash2042 Tile Forum/Advice Board 1 06-29-2005 02:42 PM
Mixing grout larleb Tile Forum/Advice Board 7 08-23-2004 08:37 PM
