Old 08-01-2010, 11:47 AM   #1
Bob Bob
holes in tub/shower tile for spout/handles
Tile is up over hardibacker/RedGard. What do I do with the gaps between "pipes" and edges of tile? Water won't get past the Redgard into the walls, but don't you want to keep the water from getting behind the tile? Should you grout the hole? Don't worry about it and let the little cover do-hicky protect it? Caulk it?
Bob Bob is offline   Reply With Quote
Old 08-01-2010, 12:46 PM   #2
tilejoe's Avatar
The escutcheon plate will keep the water at bay.
Joe Lenner
Infinite Ceramic & Stone
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Old 08-01-2010, 01:20 PM   #3
I like to 100% silicone that hole shut. Like this
Old 08-01-2010, 02:03 PM   #4
Welcome, Barb.
You need to attach your photo using the Manage Attachments feature below the Reply dialog box.
Old 08-01-2010, 04:15 PM   #5
Bob Bob
Thanks for the suggestions. I think the silicone looks like what I need.
I will try again to post the pic, just for practice! (Tried again - "upload failed" message.)
Old 08-01-2010, 04:27 PM   #6
Dave Taylor
Dave Taylor's Avatar
How big in bytes is/are the pics your trying to upload?
Use whatever software is available to you to cut the total byte size of each pic before you try to upload it/them.
I use simple ol' MS paint and either the Image > Stretch/Slew or Attributes functions after placing a pic file in the software.... then I save the pic from Paint as a jpeg file.... then I upload the jpeg file from the it's saved area to the forum.
I hope this helps.
Dave T (DIY'er)
the net.
question about tub spout?? organick Tile Forum/Advice Board 14 10-06-2009 05:37 PM
spout for the tub tunafish Tile Forum/Advice Board 2 07-04-2006 08:38 AM
tub spout question cbrash Tile Forum/Advice Board 8 04-10-2006 08:24 PM
Tub spout ideas?? claycarson Tile Forum/Advice Board 6 03-25-2005 08:59 PM
Advice on Tub Fill Spout ? dreamer Tile Forum/Advice Board 28 09-20-2004 07:20 PM
