Old 07-01-2010, 08:04 PM   #1
TexasRedNeck
Charles' Exterior Travertine
I've been lurking for a while and reading. I see many contributors that contradict each other about whether to seal before or after grouting unfilled travertine.
Here is the situation: Modest tile experience but failrly handy. 27x14 covered patio with a 30 ft sidewalk uncovered. Scabos Travertine chiseled edge unfilled Versailles pattern 1/16 or less joints (bigger as the chiseled gets filled for sure) using medium bed modified white mortar. And to make matters more complicated I laid it on a diagonal. I now know why installation for that would have been expensive, however it is done and looks good.
I want a color enhancer because I like the deep color look when it is wet. The Scabos is very porous (large voids) which I don't mind filling.
So guys, seal before grout or not......and I'd like some of your logic behind your choice please.
Thanks for contributing to such a great forum. Picture attached of project prior to completion.
Charles
TexasRedNeck is offline   Reply With Quote
Old 07-01-2010, 08:11 PM   #2
dhagin
Sealers are bond breakers. Grout/fill all then seal.
dana
Old 07-01-2010, 08:13 PM   #3
Charles,
I agree. I think that stone would look great color enhaced. Aquamix makes an excellent enhancer, along with a few other manufacturers. Test sample first as always.
When sealing the travertine you'd want to seal the top only, not the sides, not inside the pocks. WIth that in mind, you wouldn't spray on the sealant nor swab it on with a mop. I'd use a foam roller and a lot of patience. You'll spend some time doing this. It isn't like painting a wall. You'll be paying attention to every square inch as not to miss a spot and not to get the sealant all over the place, all the while making sure not to get too much in the pocks. Simple really.
Sealing first preserves the natural variation more. If you grout first, you'll blend the tiles with a much more even tone. Some people think that blands down the stone. Some times that is used to unify the stone.
Old 07-01-2010, 11:02 PM   #4
TexasRedNeck
seal and grout
Thanks Paul, Sounds like more labor but worth the effort. Your web site is impressive. Might ring you on the next project and leave it to the pros.
Charles
Travertine Pavers Exterior bctile601 Professionals' Hangout 7 12-09-2009 12:22 PM
Charles' first bathroom remodel bookhouse Tile Forum/Advice Board 15 04-01-2009 02:13 PM
Exterior Travertine with Modified Thinset locolupee Tile Forum/Advice Board 2 06-23-2008 12:22 PM
Looking for an installer in St. Charles, IL AnnieL Professionals' Hangout 1 09-24-2007 05:21 PM
Tile installation company needed-St. Louis/St. Charles area Carrie1000 Professionals' Hangout 2 07-28-2006 07:20 PM
