Old 06-03-2010, 12:49 AM   #1
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Spectralock with wave shaped glass tile
Anybody set or try to epoxy grout these tiles? My main concern is epoxy grouting the wave shaped ones. They are an accent row for a shower I am estimating. On each wall of the shower (normal 3' x 5") there is a vertical strip going from floor to ceiling. The side walls is about 1' wide the back wall is almost 3' wide by 8' tall. The flat glass tile is an accent border on the shower floor.
The other tile is a shell tile from Bedrosians. It may be used on an accent wall outside the shower. The grout spec is for Spectralock but the spec for the tile from Bedrosians says use only use an unsanded grout because the shells scratch easily. But spectralock has never scratched any glass I have down before.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Old 06-03-2010, 04:27 AM   #2
tilemanct
Tile & Stone
CTEF Certified Installer
Old 06-03-2010, 06:26 AM   #3
Is that frosted glass? I have a hard time preventing sponge marks on frosted glass when using epoxy grouts.......
Old 06-03-2010, 07:14 AM   #4
paul newton
I work at Bedrosians and i have never seen this shell grouted, how do you plan on grouting? i
We have a solution for your tile & stone needs
Operations Manager
Paul Newton
Bedrosians Jacksonivlle
www.bedrosians.com
904-458-8000
fax 904-733-0766
paul newton is offline   Reply With Quote
Old 06-03-2010, 07:29 AM   #5
Shawn Prentice
I agree with no grout for that style. Like Paul, I haven't ever seen it grouted and don't know how you could.
Shawn Prentice is offline   Reply With Quote
Old 06-03-2010, 08:05 AM   #6
gueuzeman
Whoever is writing the spec to use these in a shower and grout w/ spectralock needs to show up and give a demo on how to do it.
gueuzeman is offline   Reply With Quote
Old 06-03-2010, 08:38 AM   #7
SP100 beta tester
EPOXY GONE WILD!
SP100 beta tester's Avatar
Amen! ^
MM
SP100 beta tester is offline   Reply With Quote
Old 06-03-2010, 09:38 AM   #8
The shell tile is not for the shower. Accent wall in the bathroom outside the shower. I'll tell them no grout on that.
I trying to figure how to actually get the epoxy into the joints of the wave tile. Don't think a float would work too well.
Isaac
Maui, Hawaii
Old 06-03-2010, 11:25 AM   #9
tilemanct
Tile & Stone
Have the distributor and the tile manufacturer do an actual demo in front of you on the grout process. Make sure to do the time study! Please video it for us.
Old 06-03-2010, 09:26 PM   #10
Jhereg
Signature Tile - Owner
Jhereg's Avatar
Like a bathroom design done by a homeowner who is an engineer. Looks good on paper but the execution.....
Love the glass, but seems impossible to grout and not have the grout lines vary in thickness all over the place, ruining the clean lines of the wave.
Don't see how you can grout short of fingertips into every nook and cranny and trying to figure out how to get a clean wipe in all the same spots.
Chad N. owner
Signature Tile - Renton, Washington
www.signaturetile.net (a work in progress)
Jhereg is offline   Reply With Quote
Old 06-03-2010, 10:23 PM   #11
It's an interior designer job. Well for a GC but designer choose tile. If I get it I will give progress reports/photos.. Don't know about filming it. Not like I have my own YouTube channel.
Isaac
Maui, Hawaii
Old 06-03-2010, 11:32 PM   #12
gueuzeman
You can guest host it on my channel..
I need new content.
Old 06-04-2010, 04:11 PM   #13
JC
can you grout the wall and embed it into the grout and paint brush it from the front? maybe worth an test run.
JC is offline   Reply With Quote
Glass mosaic wave ChrisRobertsTile Professionals' Hangout 4 08-20-2007 10:07 AM
diamond shaped tile? mad1ben2 Tile Forum/Advice Board 8 01-17-2007 08:32 AM
heat wave gary The Mud Box 13 08-04-2006 03:53 AM
L shaped glass block wall for shower Darren.T Tile Forum/Advice Board 1 03-28-2006 08:00 AM
Shock Wave Textile The Mud Box 4 02-11-2003 03:57 PM
