Old 06-02-2010, 12:26 AM   #1
trvlbum
Sanding Thin Set Mortar
New guy here. Just did the thin-set mortaring of the seams around my tub. I went past the concrete board on the ends and onto the drywall with the mortar and am now thinking that was careless and is going to look really bad if i try to paint over it as it in no way has the same texture as the drywall or the drywall compound I am using. Duh. What is the best thing to try and sand the mortar off with so I can get back down to the drywall compound underneath (or right to the drywall and compound over it again)?
Thanks.
trvlbum
trvlbum is offline   Reply With Quote
Old 06-02-2010, 01:06 AM   #2
Welcome to the forum, Travel Bum...
If you juuuuuuuuuuust did it, grab a sponge and clean it off.
If the thinset is dry, trying to sand it or scrape it will result in damaging the surface of the drywall. I'd patch over the non-tiled areas with drywall compound.
Old 06-02-2010, 07:43 AM   #3
....but wait until after you set your tile to use more joint compound.
then once you have your bullnose edge set you can finish off the small area that needs it.
Old 06-02-2010, 08:33 AM   #4
Scott_V
This is an easy fix:
1) set tile as planned
2) once tile is set and grouted, take a stiff 3" putty knife and make a light pass to remove any loose thinset, then simply skim coat over the excess thinset with joint compound leaving the wall smooth and ready for primer. If the excess thinset has any high points, instead of using sandpaper get yourself a rub brick at Home Depot and carefully grind it down. Don't worry about scuffing the drywall 'cause the skim coating will cover it.
Scott_V is offline   Reply With Quote
Old 06-02-2010, 08:40 AM   #5
the brick might be a little to rough/coarse for your thinset & wall.
since it's a small area I would stick with the sandpaper.
Old 06-02-2010, 08:50 AM   #6
trvlbum
thanks
thanks guys. only 12 hours on this site and already i have solutions and no need to sweat. i love forums. i you're ever in Panorama BC the beers on me.
trvlbum
Old 06-02-2010, 09:33 AM   #7
Scott_V
The brick will work fine to knock down any large bumps....I've done this type of thing many times. Since he's skim coating the area with joint compound no need to worry about minor scuffing of the existing DW. Sandpaper is fine for smoothing, but it is the wrong approach for large bumps.
Thin-Set Mortar Question jkspup22 Professionals' Hangout 4 09-01-2008 08:23 AM
Thin set mortar? Plumb Crazy Purple Tile Forum/Advice Board 7 05-27-2008 09:41 AM
thin set mortar consistancy jvl Tile Forum/Advice Board 3 01-05-2008 11:31 AM
Making thin set mortar Theolgian Tile Forum/Advice Board 4 11-06-2007 09:10 AM
Thin Set Mortar Consistency Unregistered Tile Forum/Advice Board 4 09-28-2004 03:02 PM
