Old 03-02-2010, 04:25 PM   #1
cawall
Applying Epoxy Grout On Granite Tile
Hi!! I'm a newbie to this forum and I'm going to be doing a granite tile countertop job for our kitchen.
I've done 10 - 12 DIY tile jobs with both slate & ceramic tile before -- both floor and countertops. But I've never used granite or epoxy grout before. I'd really like some advice.
My plan is to use Baltic Brown 12"x12" granite tiles with the grout color as close to black as I can get. The tiles will be butted together (no spacers).
My questions:
1). Is epoxy grout hard to clean off the granite?
2). Will water clean up the grout -- or do I need special chemicals?
3). Do I seal the tiles before I apply the grout?
4). Do I seal the grout after it has has set for several days?
5). Will I have problems forcing the grout into the very narrow separations between the tiles?
6). Who's epoxy grout is best (mfgrs names appreciated)?
7). Is epoxy grouting substantially more difficult than an unsanded grout, ceramic tile installation?
TIA for any advice you can give me.
Chuck
Chuck
cawall is offline   Reply With Quote
Old 03-02-2010, 04:36 PM   #2
hbrothberg
hbrothberg's Avatar
Chuck:
Full Disclosure - I am biased. I work for Laticrete. We manufacture SpectraLOCK "Stainless" Epoxy Grout.
OK, so now to your specific questions:
1). Is epoxy grout hard to clean off the granite? - if you purchase the "right" epoxy grout, NO, it will not be hard to clean off of the granite.
2). Will water clean up the grout -- or do I need special chemicals? - Clean up with water.
3). Do I seal the tiles before I apply the grout? - usually not needed
4). Do I seal the grout after it has has set for several days? - A "good" epoxy grout requires no sealing.
5). Will I have problems forcing the grout into the very narrow separations between the tiles? - Should be no problem grouting joints from 1/8" up to ....
6). Who's epoxy grout is best (mfgrs names appreciated)? - Note - I am biased ...! SpectraLOCK from Laticrete Int'l
7). Is epoxy grouting substantially more difficult than an unsanded grout, ceramic tile installation? - No
Henry
Henry Rothberg
hbrothberg@laticrete.com
www.laticrete.com
Office: (203) 393-0010 ext 202
Cell: (203) 988-1814
Full Disclosure: I am a 2nd generation Laticrete guy !
Follow my Blog: www.laticrete.blogspot.com
hbrothberg is offline   Reply With Quote
Old 03-02-2010, 04:55 PM   #3
cawall
Henry -- Thanks For The Info!!
Henry --
Thanks for the info -- I'm feeling more comfortable with epoxy now. One little thing I want to double check. My grout joints will be less than 1/8" -- probably closer to 1/16" -- if I do things right. Any problem?
Chuck
Chuck
Old 03-02-2010, 05:43 PM   #4
Chuck,
I don't work for Laticrete, just use their products. What Henry said is correct. From my hands on experience, you shouldn'e have a problem. I am thinking you have highh polished granite, right? the usual stuff we see all the time and not "flamed" granite (which is really rough and normally installed outside for traction in bad weather.
Old 03-02-2010, 06:17 PM   #5
JIMMY G
Chuck,
I am a DIYer myself and just used spectraLOCK last weekend on a bathroom floor with 12 x12 tile 3/16 spaced. I have to say at first I was worried as it seemed hard to spread and I hated the hard epoxy float. I switched to a regular grout float and had better luck. I still was not happy with the finish. Then I waited 30 minutes and did the first wash. This is when I started to feel better. The grout smoothed to a real nice finish and it was easy to clean off the residual haze. The second wash was done an hour later and I was pleased with the final look. I would recommend you practice to gain a feel for how to apply. I started in a closet area. My last comment is buy a little more then you think you will need. It doesn't go far. I want to be clear to anyone reading this that I am more then pleased with the results and would use it again. I really am looking forward to the fact I don't have to seal it and it won't stain. From what I read it won't crack either.
JIM
JIMMY G is offline   Reply With Quote
Old 03-03-2010, 01:46 AM   #6
Higher Standard Tile
Tile and Stone Contractor
Higher Standard Tile's Avatar
Chuck,
The Spectralock is the way to go. Just follow the instructions. Even experienced tile guys that haven't used epoxy get into trouble if they use the same techniques they use for standard grout.
Spectralock is so much easier that what epoxy used to be like. Just get the haze of the same day. Don't wait until the next day to buff the haze off the way you might with unsanded.
Laticrete even gives use special detergent powder to put in your wash water to take care of the haze.
Isaac
Higher Standard Tile & Stone
Maui, Hawaii
Old 03-03-2010, 06:01 PM   #7
cawall
Thanks To All For Your Help
Thanks to all of you who have replied for your help. As far as I'm concerned this is the BEST board for tile expert wannabies!! I'm glad I got the "heads up" on this forum from the folks at Bedrock Creations (great guys too).
Chuck
Chuck
Epoxy grout and granite tile ragdoll Tile Forum/Advice Board 9 05-02-2011 08:17 AM
Do I seal Granite Tile before I spectralock Epoxy Grout it? kperkins411@hotmail.com Tile Forum/Advice Board 3 03-05-2009 10:23 AM
Epoxy Grout and Granite Tiles 3/8" Spacing Kuma Tile Forum/Advice Board 2 12-14-2005 12:25 AM
Granite Tile Epoxy - Please Help Lisa PA Cleaning, Restoration and Sealing 2 04-17-2004 10:01 PM
Granite Countertops/Epoxy Grout larrybunt Tile Forum/Advice Board 12 05-31-2002 06:16 AM
