Old 02-24-2010, 12:14 PM   #1
lpandrock
Bleach/Water to clean Travertine shower floor
Hi eveyone...
I have been using a light mixure of bleach and water to clean my tumbled 2x2 travertine shower floor. Will this strip the sealer I use? I ok with using this?..Reason is I noticed in areas that the grout has a pink tint to it from mildew where the water tends to sit outside the preslope..I would hate to have to seal everyime I clean but the bleach and water seems to work well, unlike many of the stone safe cleaners I have used in the past...Am I doing damage to my grout over time?
Thanks...Lance
lpandrock is offline   Reply With Quote
Old 02-24-2010, 01:33 PM   #2
Hey Lance, hope your not messing up the Travertine I did.
the bleach is high in pH, around 12.
it's also probably etching away at the travertine.
I would use a Stone friendly cleaner and sealer regularly.
Old 02-24-2010, 01:39 PM   #3
lpandrock
hahaha..yes Brian...all still looks great!!!..i was using a dilution of bleach and water to get rid of that pink mildew..the stone cleaner is not strong enuff
Old 02-24-2010, 01:40 PM   #4
lpandrock
and its only on the floor...the walls are not an issue
Old 02-24-2010, 01:58 PM   #5
the pink stuff isnt mildew, It is a airborne bacteria called Serratia Marcescens.
It likes damp conditions and is commonly found growing in bathrooms (especially on tile grout), where it manifests as a pink discoloration.
I would put in a bigger more powerful ceiling fan or leave your shower door open to help it dry faster. it also feeds off phosphorus containing materials such as soap and shampoo residue.
it says to clean with a bleach mixture but in your case with having travertine it's not good.
Serratia Marcescens Bacteria
others might have an idea.
Old 02-24-2010, 04:06 PM   #6
lpandrock
Thanks Brian...Look forward to working with you again on my kitchen and remaining baths
Yes...any help would be great as far as a solution..I have been using AquaMix Stone cleaner but just does not want to get rid of the pink bacteria stuff
How to clean glass mosaic tile around a salt-water pool? kysersohse Cleaning, Restoration and Sealing 2 04-16-2010 01:35 PM
tumbled travertine shower walls. How to clean where to find cleaner?? dnlchuffman Cleaning, Restoration and Sealing 1 07-06-2008 08:07 AM
Hot to clean hard water stains off marble sink Joe A. Cleaning, Restoration and Sealing 4 02-27-2005 02:03 PM
Christmas Tree, Travertine and Bleach Rodney G Cleaning, Restoration and Sealing 3 01-04-2005 09:43 PM
How to clean Travertine floor? sapo Cleaning, Restoration and Sealing 1 12-22-2004 11:49 AM
