Old 02-16-2010, 08:07 AM   #1
Mr. Bell
Best way to waterproof particle board?
I have a residential bathroom that has a particle board subfloor. Removing the particle board is not an option. I am using DITRA as a substrate but I have read that particle board is the worst possible subfloor.
What is the best option to waterproof the particle board? I've read that Laticrete 9235 can't be used on particle board either.
Thanks for your help, Mark
Mark
Mr. Bell is offline   Reply With Quote
Old 02-16-2010, 08:42 AM   #2
jgleason
Moderator - Theatre Guy (and computers)
jgleason's Avatar
Hi Mark,
There really is only one option - remove the particle board. Not the news you want to hear but it is the only solution you have if you want a long lasting tile floor.
Old 02-16-2010, 08:42 AM   #3
Davestone
Florida Tile & Stone Man
Mark, you literally can't put a tile floor over particle board.
http://Davestonestile.com
Old 02-16-2010, 10:19 AM   #4
The Kid
The Kid's Avatar
Hi Mark,
What is stopping ya from removing that PB?
Jeremy
Cascade Tileworks,llc
Licensed, Bonded & Insured
WA Lic# CASCATL894QA
The Kid is offline   Reply With Quote
Old 02-16-2010, 10:27 AM   #5
Mr. Bell
What is stopping me from removing the particle board is time and money.
Is it possible to cover the particle board with cement board if I mechanically secure it and cover the screws and joints with fiberglass tape and mortar?
Mark
Old 02-16-2010, 10:30 AM   #6
Shaughnn
Trowel Monkey
Shaughnn's Avatar
Mark,
The particle board is sitting on top of either a plywood or OSB subfloor. It has to come up. Sorry
Shaughnn
Old 02-16-2010, 10:31 AM   #7
JTile
Southern Delaware Tile Contractor
JTile's Avatar
The time and money will be far less now to replace it than it will to replace the entire tile job once completed.
Justin
Kyle's Tile LLC
Ocean View, Delaware
www.KylesTile.com
JTile is offline   Reply With Quote
Old 02-16-2010, 11:03 AM   #8
jgleason
jgleason's Avatar
The pb should definitely come out but there aren't any tile police so you can leave it down and take a chance. Only you can decide whether to risk it or not.
Option 1 - Take the PB out.
Option 2 - Snapstone tile can be laid over particle board. No thinset, the tiles snap together.
Option 3 - Make sure the PB is securely fastened and is as flat as possible, sand down any high spots. Get some self-adhesive EasyMat and install on top of the PB. Tile as usual.
Option 4 - As option 3 but use cement board instead of EasyMat. Do not thinset it to the PB. Fasten with backer screws. Lay Ditra on top of the cement board and tile.
Old 02-16-2010, 11:04 AM   #9
We care too much around here and know that you can't afford to do this project twice, so we don't want to condone any sort of method for building an expensive tile floor over such an incompatible product.
Methods of building solid, long-lasting tiled floors has been exhaustively tested. Particle board and tiled floors don't get along. If a manufacturer could come up with a viable, long-lasting solution for tiling over inferior substrates like particle board, they'd make tons of cash.
Swap out the PB or choose a different material. Perhaps DuraCeramic?
Particle Board jiavarasm Tile Forum/Advice Board 7 08-02-2007 11:55 AM
backer board mortared and nailed over particle board jjjjhh Tile Forum/Advice Board 5 05-09-2007 10:48 AM
Particle Board... bigfrank549 Tile Forum/Advice Board 5 03-09-2007 02:00 AM
It is particle board? Susvc Tile Forum/Advice Board 18 03-30-2005 11:29 AM
Particle Board DaTileJedi Professionals' Hangout 8 09-05-2004 09:32 PM
