Old 02-13-2010, 09:51 PM   #1
Colman
Colman's Powder Room Project
1st time laying tile. I'm starting with a small 6' x 3' pwder room (no shower or tub). I stripped the floor down to the tongue and groove subflooring. I was going to put down 1/4" hardibacker and then tile. Do I need to use 3/8" plywood uder the hardibacker?
Colman
Colman is offline   Reply With Quote
Old 02-13-2010, 10:24 PM   #2
streamline
ryan
streamline's Avatar
as long as you thinset the hardyboard to the tongue and groove and nail or suggested screw into the joices you shouldn't need plywood.
ryan
streamline is offline   Reply With Quote
Old 02-13-2010, 10:32 PM   #3
Jaz
Michigan Tile Pro
Jaz's Avatar
Hi Coleman,
Sorry Ryan but you are wrong on this one. Coleman, you need plywood for sure. I would recommend 1/2" B/C underlayment, then the 1/4" Hardie with thinset, tape & fasteners etc.
Jaz
Troy, Michigan
Custom TileSetter (retired) - Method & Product suitability consulting
DIRECT Containers MARBLE from ITALY - GREECE; PERLATO di SICILIA - PERLATINO - BOTTICINO - THASSOS - SIVEC - VOLAKAS - ARETI WHITE - CALACATTA - others - Slabs - Tiles - Custom marmo.sicilia@yahoo.com
Old 02-13-2010, 10:57 PM   #4
correct
Old 02-13-2010, 11:27 PM   #5
Hi Ryan,
We aren't perfect around here, but when advice is dispensed against industry standards or manufacturer's directions, it's generally corrected. Jaz and Paul are correct in the need for plywood (at least 3/8" CC exposure 1, plugged and sanded).
The reason for the plywood is dimensional stability. Solid wood, like that T&G subfloor, expands and contract too much to install backerboard directly over. Plywood is far more dimensionally stable.
Secondly, it sounds like you're recommending screwing the Hardibacker directly into the floor joists. That's also incorrect. The Hardibacker should be fastened to the plywood only with screws that won't penetrate into the joists...there are special screws Hardibacker sells that are only 1 1/4" to 1 5/8" to help out in this department...this method of install helps isolate some structural movement from reaching the tile assembly.
One last thing, Ryan...It sounds like you might be a pro. If so and you'd like to help out with answering questions, please introduce yourself in the Pro's Hangout. We're a friendly bunch, but like to know a bit about the folks who are dispensing advice on our forum.
Old 02-13-2010, 11:41 PM   #6
streamline
ryan
streamline's Avatar
Thanks for explaining the reason for plywood..I will try to be more careful on the advice I give
ryan
Old 02-13-2010, 11:45 PM   #7
InJuxHurYlem
So the plywood is screwed directly to the subfloor and then thinset under the hardibacker? Or do you put thinset under the plywood too?
Joshua
InJuxHurYlem is offline   Reply With Quote
Old 02-13-2010, 11:49 PM   #8
streamline
ryan
streamline's Avatar
I would like to call myself a tile setter .I am finding myself to be humbled by this forum. I am realizing I have just touched the surface when it comes to flooring. Thanks for the wisdom
plywood would be nailed every four inches on seems and six to nine in center joices,no thinset under plywood. Im sure they would agree.
ryan
Old 02-14-2010, 12:02 AM   #9
correct, no thinset or glue under the plwood
Old 02-14-2010, 01:03 AM   #10
With that thin 3/8" plywood that doesn't like to lay flat, 4" O.C. around perimeter and 6" O.C. in the field. Take a look at this thread in the Liberry on Plywood Floors.
In the same thread, also note this article on Position of Underlayment written by Peter Nielsen and Dr. Woeste.
Old 02-14-2010, 08:12 AM   #11
Colman
Thanks everyone for your detailed responses, very helpful. One thing I neglected to mention is that I only have 3/4" to lay flush with the toilet flange. Prior floor had tile around outside of toilet, It did not look good.
Colman
Old 02-14-2010, 08:35 AM   #12
Brian in San Diego
Brian in San Diego's Avatar
Colman,
If you can't replace the toilet flange (but I would consider it if it's old) you can lay tile and be higher than the flange. Wouldn't make an inspector's day but it's done all the time. Then one would use a flange spacer to get the flange at the finished floor height.
Old 02-14-2010, 09:58 AM   #13
jgleason
Moderator - Theatre Guy (and computers)
jgleason's Avatar
But to be really correct the toilet flange is set on top of the finished flooring.
From the Liberry -Toilet Rough-In
Old 02-14-2010, 12:04 PM   #14
Colman
This question is going to show my inexperience, but should I use nails or screws to fasten the plywood. I will be using the hardibacker screws to attach the hardibacker. Thanks.
Colman
Old 02-14-2010, 12:11 PM   #15
Edthedawg
Edthedawg's Avatar
Colman, get yourself some decking screws approx 1/4" max longer than the total thickness of the ply and the t&g boards below. then screw away, following the perimeter/field schedule given above.
I like Deckmate or Phillips-Squar-Driv screws from the box stores myself.
Ed
GO SOX!
help me glam up a powder room lilacpimlico Tile Forum/Advice Board 5 07-06-2008 07:09 PM
1920's powder room project lyndam Tile Forum/Advice Board 7 09-26-2007 07:08 PM
Powder room redo... jgleason Tile Forum/Advice Board 8 11-13-2005 08:48 PM
Powder Room Floor James M Parks Tile Forum/Advice Board 3 01-13-2005 08:42 AM
Tile for the Powder Room kenkm Tile Forum/Advice Board 7 08-29-2004 08:30 PM
