Old 01-12-2010, 11:31 AM   #1
Yvan
Sharp tile edges on floor
Hello everyone,
This is a great site, been looking around for a few days now!
I'm working on a bathroom floor, and I cut some of the 12" tiles down to 4" to make a decorative border. The small pieces have sharp edges where I cut them with a tile cutter. Should I sand those edges off before installing the tiles, or will grout totally protect people with bare feet from finding the sharp edges?
Yvan Roy
Yvan is offline   Reply With Quote
Old 01-12-2010, 11:36 AM   #2
Davestone
Florida Tile & Stone Man
Typically we would use a rubbing stone.
http://Davestonestile.com
Old 01-12-2010, 11:45 AM   #3
is this ceramic, porcelain or marble ?
did you cut them with a snap cutter, grinder or wet saw ?
Old 01-12-2010, 11:47 AM   #4
Saldibs
Tile Contractor -- Boston North Shore
Saldibs's Avatar
Send a message via ICQ to Saldibs
Like Davestone said, Rubbing stone will ease the edge.
Sal
http://www.youtube.com/saldibs
There is a right way and a wrong way, take your pick!!
You can only choose one!
elitetileco.com
Saldibs is offline   Reply With Quote
Old 01-12-2010, 12:15 PM   #5
Yvan
Thanks for the replies!
These are ceramic floor tiles with a thin glaze, I used a snap cutter.
I'll have to see if I can find a rubbing stone, but I'm wondering if something else might do in a pinch
Yvan Roy
Old 01-12-2010, 05:14 PM   #6
Yvan
A friend lent me his benchtop 4" belt sander, and it seems to be doing a good job of taking the edge of the tiles. The tiles happen to be 4" inches square, so it works great.
Tomorrow I will hot glue them to 6" wide strips of fiberglass mesh on a diagonal. We will lay them along the perimeter of the bathroom.
Yvan Roy
Old 01-12-2010, 05:16 PM   #7
scuttlebuttrp
concrete driveway.
Brick laying on the side of the house.
These may chip tile easier though.
That stone you use to sharpen your knife with.
That will ruin the stone though? Maybe?
Royce
Old 01-12-2010, 05:17 PM   #8
scuttlebuttrp
Hot glue?
Why not just install them straight into thinset?
Royce
Old 01-12-2010, 08:47 PM   #9
Yvan
Okay, so I guess anything can take that edge off... That's good to know. So far the belt sander is working real quick! I have a fair amount to do.
For the other bathroom I hot glued a pattern of small tiles (about 400 2"x2" tiles) onto mesh first, you can place them easily and accurately. Then when we put the thinset on the floor or wall I just slide the whole design into place. Very fast. No cutting or fiddling needed, it's just done!
This pattern is mostly 4"x4", so I'm not sure if I'll do the same thing. Might not be worth it...
Yvan Roy
Old 01-12-2010, 08:51 PM   #10
custombuilt
80 grit metal grade sand paper in your hand will do the job quickly.
Jason W.
Superior Construction
Quincy, IL
Old 01-13-2010, 08:22 PM   #11
Yvan
Okay thanks for the suggestion, I've got some metal sandpaper, assorted grits. I've glued the border to mesh, gave me a chance to see a few trouble spots ahead of time. So tomorrow I'll add in little bits and might try to sand them by hand.
Yvan Roy
sharp tile edges at carpet transition mad1ben2 Tile Forum/Advice Board 4 11-14-2006 12:16 PM
Rounding the sharp edges on porcelain dchall8 Tile Forum/Advice Board 4 09-08-2006 06:17 PM
mosaic tile and sharp edges textucker Tile Forum/Advice Board 12 03-22-2004 12:51 PM
Breaking sharp edges on Porcelain Dano Professionals' Hangout 15 09-27-2001 05:20 PM
Breaking sharp edges on Porcelain Dano Tile Forum/Advice Board 4 09-19-2001 04:17 PM
