Old 12-21-2009, 06:45 AM   #1
bob22
THinset working time
First time mixing up thinset from the bag. The last time I used premixed. Any general rule for working time for modified thinset? I'm having a tough time estimating how much water to start with for the amount of dry mix and end up mixing too much thinset.
I have a 50 lb bag with about half left from the Hardibacker installation. What is left should be more than enough for the tile install if I mix it right in smaller batchs; otherwise it will set up too fast and get wasted. To do an area about 3' x 3', how much water to dry mix?
Bob
Bob
bob22 is offline   Reply With Quote
Old 12-21-2009, 07:03 AM   #2
Bob, the thinset bag has a list of times on it. Working time, pot life, etc. Pot life is how long it stays good in the bucket. Working time is how long you have to get the tile in it's final position before you mess up the bond. These times are considered absolute maximums, so try to leave yourselve some margin.
The bag also says how much water to mix. It may tell you how much to mix for 50 pounds, though. You'll have to measure the thinset by weight and add the correct proportion of water. After you do a couple hundred bags, you'll be able to estimate it by eye, but for now, weigh and measure.
Old 12-21-2009, 08:22 AM   #3
Remember, if you don't mix enough the first time, you can always mix a little more. But if you mix too much, you can't "un-mix" it.
1st time tiler working with colorbody textured porcelain Court Tile Forum/Advice Board 6 04-05-2009 11:22 AM
What time do you start working? tileguytodd Professionals' Hangout 69 06-21-2006 03:39 PM
grout working time fosters351 Tile Forum/Advice Board 7 04-05-2006 05:25 PM
Deck mud working time vdocad Tile Forum/Advice Board 10 06-20-2005 05:01 PM
Working time for thinset ehlinn Tile Forum/Advice Board 6 02-16-2005 03:16 PM
