Old 12-04-2009, 07:23 PM   #1
wristen
tile contractor
shower pan liner outside corner?
Hi I have a 5"x6" curb less shower the opening is 5" wide the sub floor in the shower is 2 1/2" lower then the sub floor. It has a curb on one side that returns one foot to make the opening 4" wide any ideas on how to make corner (outside corner) the end of the curb ?
thank you for your input,
Wristen
wristen is offline   Reply With Quote
Old 12-04-2009, 07:38 PM   #2
I think it would be helpful if you were to post us a photo or two of what you've got there, Wristen.
I'm thinking some of your posted dimensions should be in feet rather than inches, but even working around that I'm not sure what your layout is.
Perhaps some others can see it better from where they are.
Then give us a hint what material your shower pan liner is.
Old 12-04-2009, 07:52 PM   #3
since your on a slab you will have a hard time using a liner.
maybe a liquid membrane will be better suited for you.
Old 12-04-2009, 07:56 PM   #4
Mmmm, Brian? Why would that be?
We use liners alla time in showers on SOG.
I know y'all don't use'em at all in Florida, but most places actually waterproof their pans. Really they do. I am not making that up.
Old 12-04-2009, 08:10 PM   #5
so how would you waterproof a curb less shower with a liner? splain to me
I only use Kerdi or a liquid membrane.
Old 12-04-2009, 08:28 PM   #6
wristen
tile contractor
This the best I can do until I get to the job. you just run the liner out past the opening a foot or to the point where no water will be I hope this will help I will get a better photo next week
thanks
Wristen
Old 12-04-2009, 08:34 PM   #7
wristen
tile contractor
will hydroment ultra-set advanced bond to the pvc (oatey )pan liner ?
Wristen
Old 12-04-2009, 08:59 PM   #8
so your wanting to do a curbless with a liner on a wood subfloor?
I would look into Kerdi and Ditra to make the whole area waterproofed.
Old 12-04-2009, 09:13 PM   #9
dhagin
Then what? Shoot a bunch of holes in it when you put CBU down?
edit; i guess you could do a mud floor...
dana
Old 12-04-2009, 09:18 PM   #10
I can 'splain you, Brian, sometime not on a visitor's thread.
If you're on a wood subfloor, Wristen, you're really gonna hafta go with a bonded waterproof membrane shower system of some kind.
Even if you're dimensions and other considerations are adequate, you're not gonna have vertical room for a traditional shower pan and make that shower curbless.
Old 12-04-2009, 09:58 PM   #11
..................i l
Old 12-05-2009, 12:16 PM   #12
wristen
tile contractor
well first of all I would only use CBU on a floor when I have a hight problem I try to always do mud even on floors wonder board is for those who can't do good mud work. I do have the room for a mudded shower floor because I will be floating the floor plus the tile will raise the floor to give me the room over 3". I need 3/4" of an inch of fall
Wristen
shower pan liner lakedanger Tile Forum/Advice Board 4 09-14-2008 11:49 AM
Shower pan liner Scott M. Tile Forum/Advice Board 4 04-13-2008 08:10 AM
Shower Pan Liner Mike Berry Tile Forum/Advice Board 117 03-09-2005 11:42 AM
shower pan liner aliaz Tile Forum/Advice Board 33 02-02-2005 06:29 AM
Shower liner corner question tada Tile Forum/Advice Board 3 05-16-2004 08:04 AM
