Old 11-02-2009, 11:03 PM   #1
Dnmeistr
Tub replacement on concrete slab
I have a 1950's house built on a concrete slab, the single bathroom is tiny with a 28" bathtub that I would like to replace with a walk in shower. I have done plenty of research from shower pans, hard to find a 28" shower pan to going with a kerdi tile install. I have lots of newby questions and hope you guys can help a newby out.
I don't want to do a full 60" shower and there is a window centered on the outside wall so it looks like I would have to go out at least 48" to go 4 to 5" past the window, leaving only 12" for shelves behind the shower. Question is can I buy a Kerdi 32x60 offset shower kit and cut the shower pan to fit, down to 28x48. I can only do as wide as 28" because the edge of the sink is 30" from the finished wall, the sink is 25" wide and I plan on replacing that as well with a smaller pedastal sink to get some more room. Also can the Kerdi drain be cut if it is to close to the wall, it is a 10" off set and measuring my tub looks like the drain is only 8" out from the finished wall.
Researching tub replacement it may have a 1 1/2" drain and I would need a 2" drain, how do I go about changing to a 2" drain, do I have to change the p trap, also how do I get access to the p trap, do I just score the concrete with a angle grinder and then break it out, how thick is it. Sorry about the plumbing questions but figured some of you might have done this before.
Also because I want to go from a 60" tub to possibly a 48" shower, I want to use two curbs to avoid building a wall and use glass back wall with either sliding door or swingout door on the inside portion, is that acceptable.
And as for a tile question, what do I look for when shopping for tile, how do you tell the good from the bad. I dont want expensive tile but don't want cheap tile either. Thanks.
Dennie
Reno, NV
Dnmeistr is offline   Reply With Quote
Old 11-02-2009, 11:34 PM   #2
Welcome to the forum, Dennie.
First, there are plenty of areas where the codes says a shower needs to be a dead minimum of 900 sq/in of floor space, with no less than a 30" measurement in either direction. That's the first thing you might wanna consider.
You can buy a kerdi tray and chop it on 3, perhaps all four sides to squeeze it into your opening. But realize the tray may hinder your installation if it doesn't reach your drain location. If you wanna keep your options open, consider mudding the floor instead.
The drain pipe needs to be 2" from the drain in the shower floor all the way out the house. Nowhere can it be reduced or be constricted with anything less than a 2" drain. So if you have a 1 1/2" drain pipe now, you're likely going to need to replace a run from your tub over to where the drain meets up with a larger section of drain pipe. So this isn't always an easy thing to do under a slab. If you can figure out where your drain goes and meets up with other parts, you can get a better grip on how much concrete you'll need to bust open. Your floor is likely to be 3"-4" thick.
Yes, you can build a wall out of glass block if that's what you mean. Just make sure the configuration of whatever sliding or swinging shower door is sufficiently supported...you can't hang a door from a wobbly wall.
As for tile, go to a real tile store instead of a big box store for starters. It's hard to say this tile is good or that tile is bad. Rather, it's more important to choose tile that's appropriate for a shower. For example, a polished marble would be a poor choice for a shower due to the maintenance issues associated with it. A porcelain tile would be a better choice due to it's toughness and low absorptive quality. Another thing you need is consistent tile in terms of it's overall dimension...or caliber. Sometimes the big box stores have the same tile for less than a tile store and may be due in part to it's inconsistent size tile from piece to piece (not very tight tolerances on caliber). Inconsistent tiles are more difficult to install and may detract from straight groutlines.
Tub and shower replacement luvtnt Tile Forum/Advice Board 9 01-01-2009 03:03 AM
Tub to Shower on Concrete Slab - Need Help Ptyalism Tile Forum/Advice Board 1 01-26-2008 07:32 PM
Locating replacement tiles, slab problem HarleyK Tile Forum/Advice Board 3 11-26-2007 12:09 PM
Tub faucet repair + drain hole in concrete slab H20Man Tile Forum/Advice Board 7 01-04-2007 12:41 PM
Tub replacement: How to deal with drain cutout in slab. Homer Tile Forum/Advice Board 4 06-24-2002 02:22 PM
