Old 10-14-2009, 02:31 PM   #1
johnm sr
half wall between shower and tub
I am re-modelling my mst bathroom and decided to put a stub wall between my shower and jetted tub. Fiberglass pan and subway tiled walls for the shower enclosure. The walls around the tub will be tiled as well. There is a window and the other end of the tub which I will tile around also. My plumbing supply is in the half wall so control for the shower and tub will be on opposite sides of the stub wall. I am locating my shower head on the back wall so need to route plumbing for shower head with about 6' of pipe and several elbows.
Are there any issues with the pressure balanced type shower valves when the head is not directly above the valve?
Also I am thinking to cap the stub wall with a piece of granite to match what I already have installed on my sink. Is granite OK in a shower enclosure ? Maybe at least I will need some heavy sealer ?
Also I have framed in a large niche in the shower, what is the best way to water proof ? Before I hang durock or after ? I plan to tile the inside of the niche with smaller glass tiles but am unsure how to frame or transition to the subway tiles. Could I use a piece of granite for the bottom of Niche?
Any advice on the install of the glass shower enclosure as it must also enclose the stub wall?
I will try to post picts of my rough in. Just looking for advice from anyone who has done or seen similar install.
Thanks x 1,000,000
John
johnm sr is offline   Reply With Quote
Old 10-14-2009, 02:55 PM   #2
Mountain Tile
Tile Contractor -- Northeastern PA.
Mountain Tile's Avatar
You can waterproof with Redgaurd.
Mountain Tile is offline   Reply With Quote
Old 10-14-2009, 06:06 PM   #3
tilejoe
tilejoe's Avatar
Granite is just fine to use inside a shower, but as you said, a good sealer will keep it looking good for a while. You can build the niche out of durock and then apply anyone of the liquid membranes that are specified for a shower. I use granite for niche bottoms frequently.
As far as the plumbing goes, I have seen your set up done a few times. where the controls are on one wall and the heads and sprays are on another. I'm not a plumber, so I can't tell you how to do it, just that I've seen it done.
As far as the glass, I ALWAYS hire a glass company. They do the best work for my customers
Best of luck
Joe Lenner
Infinite Ceramic & Stone
www.infiniteceramic.com
NTCA Pennsylvania State Rep
CTEF Certified Installer #769
Old 10-14-2009, 06:10 PM   #4
johnm sr
Waterproof over the Durock or behind?
Or both ?
Old 10-14-2009, 06:14 PM   #5
Mountain Tile
I have seen plumbing set up with the valve on one wall and the shower head on another, no problem with that. Membrane on top of durock, not under. Be sure to use cbu mesh tape in the corners and seams where you are water proofing. Water proof the half wall as well, top and side.
Old 10-14-2009, 06:39 PM   #6
Rob The Glass Man
As Joe said, hire a professional for the shower enclosure. Especially something with a half wall, this is considered a custom door and has to be made to order.
Rob
Rob The Glass Man is offline   Reply With Quote
Old 10-14-2009, 06:41 PM   #7
tilejoe
tilejoe's Avatar
What Rob and Chuck said.
Joe Lenner
Tiling top of half wall in shower jthoni Tile Forum/Advice Board 2 02-24-2008 10:19 AM
Half wall of shower rednavel Professionals' Hangout 1 01-01-2008 10:23 AM
tub wall half tiled, how best to tile the rest? mayday Tile Forum/Advice Board 2 06-25-2006 10:24 PM
moulding and half round against wall quiltbabe Tile Forum/Advice Board 4 01-06-2005 07:24 PM
Complex curb or simple with half-wall Beagle Tile Forum/Advice Board 1 07-10-2004 08:27 PM
