Old 10-13-2009, 06:39 AM   #1
russelldav
How to remove trim?
I have to add some more tiles on to an existing installation to increase the height of the tiled area. I have everything I need except I can't work out the best way to remove a PVC tile trim that has been used to finish off the existing tiles.
It looks like this:
h t t p:// w w w.made-in-china.com/image/2f0j00MChQpvwWrPqSM/PVC-Tile-Trim.jpg
(remove the spaces in the link)
It's pretty tough stuff and I have about 2m of it to remove around a corner. How should I do it?
I heated up a stanley blade last night and it melted into it quite nicely, but I can't do that for the whole 2m it'll take forever!
Thanks in advance for your help.
Russell
russelldav is offline   Reply With Quote
Old 10-13-2009, 06:51 AM   #2
Wayne67vert
Tile Contractor
Wayne67vert's Avatar
Hi Russell,
Welcome to the forum.
To remove that trim I would use my circular saw set to just cut through it. The last area left would be done by hand with a utulity knife.
Wayne
Wayne67vert is offline   Reply With Quote
Old 10-13-2009, 06:58 AM   #3
HS345
Tile Contractor
HS345's Avatar
I would just keep scoring it with a sharp utility knife until you cut through. Might go through a couple of blades.
What ever you do, please be careful.
The name's Greg
Old 10-13-2009, 06:59 AM   #4
Muddman
Muddman's Avatar
what wayne said but I would use an angle grinder instead.
Gregg R
Muddman Design
Custom Tile, Concrete Countertops and Remodeling
St. Louis, MO
www.muddmandesign.com
Muddman is offline   Reply With Quote
Old 10-13-2009, 07:01 AM   #5
Dave Taylor
Dave Taylor's Avatar
Hi and welcome to TYW 'US', Russell.
I would use my Fein Multimaster (or a vibrating tool like it) to cut that PVC trim.
Hope this helps.
PS: How are things in the UK?
Dave T (DIY'er)
the net.
Old 10-13-2009, 07:15 AM   #6
russelldav
Thanks for the advice guys. I will go to the hardware store tonight and get a heavy duty knife to do the job as my current retractable one isn't up to the job.
The UK is getting pretty cold and autumnal thanks for asking Dave! I see no evidence of global warming
Russell
Old 10-13-2009, 08:02 AM   #7
...autumnal...
Yeah, that happens a lot this time of year.
Tiling around window and door trim--raise the trim? bek Tile Forum/Advice Board 11 07-19-2008 02:37 PM
To remove or not to remove- the shower pan Preshi8481 Tile Forum/Advice Board 2 04-16-2008 02:24 PM
To remove or not remove vinyl floor CraigB Tile Forum/Advice Board 11 03-16-2007 03:08 PM
Remove or not remove mud floor kcohio1 Tile Forum/Advice Board 3 01-17-2006 07:44 AM
Plastic tile trim / Q-trim / Anybody use it ? Erich Tile Forum/Advice Board 3 11-30-2001 06:33 PM
