Old 08-29-2009, 12:41 PM   #1
tkahn
Baseboard at tile to carpet transition
I'm putting down the last baseboards this afternoon and am at the area where my entry hallway parallels the living room where there will be carpet. The carpet installer said to put the baseboard 3/8" up from the subfloor and that he would then tuck the carpet. The tile/backerboard floor is about 5/8 high. The baseboard is 6" high heavy colonial style trim. Should I just rip 1/4" from the bottom of the baseboard where it travels onto the tile? Will that look right at the tile edge? It only needs to run a few feet until it meets door trim so I can pick it back up untrimmed on the other side of the door.
I have a good tablesaw and good compound miter saw and the skills - what I'm mainly concerned about is the appearance, not my ability to do it.
How is this usually done?
tkahn is offline   Reply With Quote
Old 08-29-2009, 05:43 PM   #2
LGB
Tile Contractor -- Pennsylvania
Yep that's how its done. I'm not a carpenter so do it as you see fit. I've see it scribed and cut with a jig saw before.
Leon
LGB is offline   Reply With Quote
Old 08-30-2009, 08:17 AM   #3
sdaniels7114
Flooring Contractor
sdaniels7114's Avatar
You could probably cheat the base up a bit higher on the carpet side too. I'm assuming this is a standard stretch-in over pad type carpet. If you're gluing the carpet down for some reason then disregard what I'm saying. You'll catch 1/4" just from the tackless strip the carpet guy needs to put along the wall, add about 75 to 90% of the thickness of the carpet to that 1/4". You can place your base that far above the subfloor and still end up with a nice full edge that the carpet guy will easily be able to tuck in. If the carpet's thick enough you may not have to notch at all.
A truly lazy person doesn't finish any
Steve D
sdaniels7114 is offline   Reply With Quote
Old 08-30-2009, 08:24 AM   #4
I leave my base in place and cut it with my Crain undercut saw.
I raise it to the thinckness of the tile & underlayment and then add an 1/8".
I only remove base on occasion but you want the tops of all your wood base to be level for sure.
Carpet to tile transtion - carpet installer coming in a week + a baseboard question tkahn Tile Forum/Advice Board 1 05-15-2009 06:13 PM
Tile/Carpet Transition Mckenzie Tile Forum/Advice Board 8 02-19-2008 07:58 PM
Carpet To Tile Transition BarbaraRyan Tile Forum/Advice Board 5 01-19-2008 10:33 AM
suggestions needed on tile to wood baseboard transition ToyMakr Tile Forum/Advice Board 6 02-07-2006 12:42 PM
Tile to carpet transition DoofusOfTheDay Tile Forum/Advice Board 8 09-26-2005 10:48 AM
