Old 08-25-2009, 09:45 AM   #1
K.G
K.G's Avatar
How High up the wall do you tile
Hi
I wanted to know, Is there a rule of thumb to how high up the wall you tile from going from the floor in a bathroom.
I'm putting a nice boarder tile around about four of the porcelain tiles on the floor just to add a little something extra.
Then want to go up the wall with the other tile we picked/adding some of the boarder and then put the cap on so everything works.
I don't know if I need to go high enough for the Vanity so I can put the cap on or just leave it.
Do I just Tile under the window and then behind the toilet and be done
The tiles on the floor are 13x13 and the border is 2x8
I only have 30 SF to work with on the floor
(Pictures)
KG
K.G is offline   Reply With Quote
Old 08-25-2009, 10:07 AM   #2
Pictures would be very helpful.
Old 08-25-2009, 12:43 PM   #3
rktect
So you are talking a wainscot? . . . I went about 40" . . . that way the tile border went over the vanity as a back splash as well, but kept it below the switch paltes so as not to need to mess with those.
Andrew
Jack of all trades and master of none . . . .
rktect is offline   Reply With Quote
Old 08-25-2009, 02:48 PM   #4
scuttlebuttrp
4' I think is normal but my last one I did was 40" for the exact reasons that rktekt mentions. You can tile to the ceiling if you want though. It's your house.
Royce
Old 08-26-2009, 02:48 PM   #5
K.G
K.G's Avatar
Updated with Pictures
I'm re-doing the Drywall half wall up,That is what was under the Baseboard
I don't want wainscot
KG
Old 08-27-2009, 03:44 PM   #6
rktect
Question
So you are not looking for something like this:
As for how high to run a base trim tile . . . 3 to 6 inches . . .
Andrew
Old 08-27-2009, 06:04 PM   #7
K.G
K.G's Avatar
yes sir,that's what I want to do
KG
Old 08-27-2009, 06:15 PM   #8
Hi Kyle, there's no reason you can't do something like that. It looks like Andrew let the shower wall on the far right control the height of the wainscot. He can correct me if I'm wrong. You could start your border piece sitting on the countertop and then fill in with wall tiles on each side of the cabinet putting the cut down against the floor.
Old 08-28-2009, 07:22 AM   #9
rktect
Exclamation
Then there you go! A picture is worth 1,000 words. Oh and FYI, that is considered wainscot. . . .
Actually being a EXTREMELY anal Architect . . . the wall mounted faucets dictated the centerline / height of the border, which in turn dicated the elevation of the "cigar" trim, which determined the height of the low wall at the shower . . . talk about a S.O.B. to design and build . . . but I did it!
Andrew
Basement bathroom wall tile - how high? hhcibtpaun Tile Forum/Advice Board 11 05-19-2009 04:20 AM
EntryWay 11 ft high white everything - High Polish Black Granite Callmebill Professionals' Hangout 5 08-09-2005 11:10 AM
How high can my tile be? Mud Bug Tile Forum/Advice Board 2 07-01-2005 01:43 AM
how high to tile my backslash jinky Tile Forum/Advice Board 7 07-18-2004 12:34 PM
How high to set wall tiles in half bath? Pdog Tile Forum/Advice Board 10 03-13-2004 03:23 PM
