Old 08-20-2009, 11:26 AM   #1
larryakoch
How to remove cemented tile intact?
I broke a couple of ceramic kitchen tiles right in front of the sink.I can't find a color match, however if I could remove a couple from under the built in desk I would be in good shape, What technique could I use to remove the tile intact?
larry
larryakoch is offline   Reply With Quote
Old 08-20-2009, 03:18 PM   #2
Davestone
Florida Tile & Stone Man
It may be impossible, but the best method is to cut the grout out around the tile, then use a very small flatbar,and tap it under the edge and gently pry back and forth to wiggle it free.
http://Davestonestile.com
Old 08-20-2009, 06:05 PM   #3
what is the tile set on ? substrate ?
I highly doubt your going to pull it off.
Old 08-20-2009, 08:23 PM   #4
doitright
doitright's Avatar
Hi Larry, Welcome!
I have to agree with the general consensus of my comrades. Besides answering Brian's questions, you could try tapping the tiles under your cabinet and see if any of them have a hollow sound to them. If so, they would be the prime candidates.
John Koessler
Old 08-23-2009, 07:06 AM   #5
plusaat
if you clear out all grout from around the tile you want to take up, then get a paint scraper and wedge it in between the tiles.sometimes you need a small piece of cardboard in too, to stop tiles chipping when prying.Then lightly tap with a mallet or rubber handle of hammer on an area of the tile and try pry it up there.You may need to do this in a few different places to get it to come loose.
plusaat is offline   Reply With Quote
To remove or not to remove- the shower pan Preshi8481 Tile Forum/Advice Board 2 04-16-2008 02:24 PM
To remove or not remove vinyl floor CraigB Tile Forum/Advice Board 11 03-16-2007 03:08 PM
Help...MUST REMOVE TILE highcountry Tile Forum/Advice Board 11 07-18-2006 12:34 PM
Remove or not remove mud floor kcohio1 Tile Forum/Advice Board 3 01-17-2006 07:44 AM
remove old tile? mmontz Tile Forum/Advice Board 7 03-15-2005 02:22 PM
