Old 08-19-2009, 06:07 PM   #1
smiley7661
smiley7661's Avatar
Send a message via Yahoo to smiley7661
Grout haze removal ( sub for cheese cloth)
In the past i have used cheese cloth to remove haW after grouting. Now I have a larger
area
is there something better?
Ron
smiley7661 is offline   Reply With Quote
Old 08-19-2009, 06:10 PM   #2
Microfiber cloths work.
Old 08-19-2009, 07:15 PM   #3
I second and sometimes even final wash a third time.
I use a blanket to get ALL the haze off the first time.
Old 08-20-2009, 11:19 AM   #4
james d
Fresh wash but here is the key (don't start freshwashing if when you rub your finger on grout it smudges on your finger Does that make sense? otherwise you just keep spreading film onto the tiles.Here is the method, new sponge clean water with no weight run sponge across tiles maybe 2' worth flip sponge and wipe next to your last run then rinse sponge and move on. When done methodically you can almost eliminate cheesecloth altogether.Here is a question do people still use lemon oil on high glaze tiles?
james Donaire
james d is offline   Reply With Quote
Haze and Grout Removal Amozz42 Cleaning, Restoration and Sealing 8 02-02-2008 08:40 PM
Grout haze removal rnelson0 Cleaning, Restoration and Sealing 11 03-27-2006 06:40 PM
Grout Haze Removal runningman06 Tile Forum/Advice Board 3 03-08-2006 08:02 PM
grout haze removal curt Cleaning, Restoration and Sealing 3 03-20-2005 03:00 PM
Cottage Cheese Ceiling Removal newhomeowner Tile Forum/Advice Board 9 02-27-2004 08:05 PM
