Old 08-16-2009, 06:43 AM   #1
Raymondo
Raymondo's Avatar
Best/favorite food grade sealer for stone tops at a restaurant?
What would you guys use for sealing stone tops going in a restaurant? Must be rated to use in a food prep/kitchen envoronment.
Casey
www.barefoot-tile.com
Raymondo is offline   Reply With Quote
Old 08-17-2009, 02:12 PM   #2
Davestone
Florida Tile & Stone Man
Casey i though for sure somebody would answer this for ya.Anyway,i think any well known sealer is fine,as long as it doesn't say it ISN"t good for food prep areas.Typically though certain granites are used in kitchens that are hard and dense enough they don't need a sealer,what kinda stone you got?
http://Davestonestile.com
Old 08-18-2009, 05:19 AM   #3
MDS
I didn't think any stones were approved for direct food contact anymore.
I don't believe there is an approval process for stone sealers in direct food contact, so I don't think you will find one. It would have to be an FDA approval, not the USDA. The latter would be for incidental contact, like on a floor or wall not prep areas like a counter top.
Mike Skala
Grouterra.com
ColorClad™ Premium ColorSeal
MDS is offline   Reply With Quote
Old 08-18-2009, 09:05 AM   #4
GraniteGirl
Ms. Makita
GraniteGirl's Avatar
Send a message via Yahoo to GraniteGirl
What stone do you have there? Some do not even need sealer.
Edit: It really irks me that the govt has issues with stone as food surface, yet they have no qualms using a plastic product impregnated with a pesticide - Microban - in places such as food service areas, hospitals and child care facilities.
Adriana
www.IslandSoapstone.com
Relax - it's a rock! What could go wrong?!
GraniteGirl is offline   Reply With Quote
Old 08-18-2009, 09:36 PM   #5
Stone Dude
Stone is ranked 2nd (behind stainless steel) for resistance to bacteria, perfectly acceptable for food surfaces.
Surface Treatment Technologies has proven to be one of the best sealers available. They also have an optional second application FE (fast evaporative) that will give the sealer a lifetime gaurantee against staining. you dont have to be a "certified" applicator.
I have Columbo Gold granite in my kitchen, the most porous granite available. 2 coats of the normal SB sealer and one application of FE. I left a pizza box, olive oil, fruit, wine and strawberries overnight to test it out. wiped everything up about 10 hours later, no penetration.
Also we are talking about impregnating sealers here. "sub-surface", technically they wont really actually come in contact with the food.
Cameron DeMille
SFA, MIA
MillestoneMarble.com
Old 08-19-2009, 04:50 AM   #6
MDS
I have seen the people selling artificial stone materials claim that granite is not FDA or USDA approved for food prep surfaces. Maybe they are lying but since "granite" can be darn near anything these days it might make sense. I don't think I want my food laying around some piece of stone from China that was doctored with god-knows-what type of chemicals. Though I think the issue is with porosity and pits.
I found this sealer that claims FDA for granite. Sounds like an epoxy which is pretty easy to formulate to clear NSF & FDA.
Pretty sure I wouldn't like an epoxy coating on my granite. Unless this is just some cheap, ugly fix when the inspector comes out and cites you for non-compliant surface.
Mike Skala
Grouterra.com
Old 08-25-2009, 06:04 AM   #7
Raymondo
Raymondo's Avatar
Thanks for the responses. The stone is Indiana limestone, which is extremely porous (and soft). Cameron, that sealer you mention sounds great. I have a catalog from Helix and they sell it. I noticed that the FE is about $1500 per gallon!!! How much of that do you think you'd need for 20 sq ft top?
Casey
Old 08-25-2009, 07:27 AM   #8
GraniteGirl
Ms. Makita
Who spec'ed limestone for a top in a busy restaurant?!
Oh boy
The STT sealers are great stuff and have to be used as a kit - SB first and then the FE. You probably would need a lot more SB than FE, but a gallon would be serious overkill for your application.
No sealer, no matter how great, will change the softness of the stone or its proneness to etching, though. Those characteristics can not be sealed away.
Edit: See if you can get a hold of TYW's own Steven Hauser. He is the chemical guru behind the STT line of sealers (and other products) and he will be able to help you with your questions.
Adriana
Favorite sealer for wet area stone counters? JQE Tile Forum/Advice Board 2 10-23-2008 07:10 AM
Favorite Sealer for Wet Look? bakerdog Tile Forum/Advice Board 1 08-17-2006 01:03 PM
Food grade sealer? Bragg Creek Cleaning, Restoration and Sealing 1 06-05-2005 02:05 PM
Pros Oppinions on Stone Tech Bullet Proof Stone Sealer RogerM Cleaning, Restoration and Sealing 17 10-08-2004 01:48 PM
Is there a truly food-safe marble sealer? danni_in_pdx Tile Forum/Advice Board 1 04-20-2004 03:38 PM
